what do you mean by speed electron?
or speed of the electron ....that can be measured by finding/measuring its mobility using hall effect based Gauss meter which on multiplication with applied electric field will give velocity of electron...also no applied field no velocity i mean no mobility
hi...KUMAR.....i think u are talking about the speed of electron when voltage is applied...but i think the guy is asking about the speed of electron inside the atom when there is no voltage difference......plzzz...reply
speed of the electron in an atom with out any external field is caused due to the resultant of coulombic force and the atomic magnetic field.when an electric field is applied then what will happen ?U can see it in the attachment.
