creepage to earth is usually from the tab to the nearest earthed metal, input to output is as it says, creepage can be from the pins ( any pin ) to earth or output as is the case required ...
working creepage is for the normal max internal ckt, safety creepage is different, usually at least 5mm in to out ( 230Vac ) and 3.2mm to earth
