rubdawg
Member level 1
burst power mesure
Hi, I am working on Zigbee (802.15.4) int the 2.4GHz band. I am trying to measure the tx burst that takes 0.64ms to transmit a packet, but with the spectrum analyzer the sweep time cannot go below 1ms. I am trying to trigger the Spectrum analyzer (PSA 4443A) but not sure if I just tap from the VCC line on our board to trigger the spectrum analyzer , or what other methods would be possible. Also I am trying to mimic the packet signal with a signal generator but ours does not have O-QPSK signal, but I know i can offset Q which would be similar correct?? Any insight would be grateful. Basically I am trying to measure PSD mask (power spectral density).
Just to give a background, i have worked on GSM and CDMA handsets and usually had a call box that handled measuring
