ICRF
Newbie
Hello,
is there a better way to match a power dependent impedance on an IC? The matching changes the power transfered to the transistor connection and therefor the transistor changes its impedance. I use Cadence Virtuoso and hb + hbsp to get the impedance of the transitor port, because a large signal analysis is needed.
Is it helpful to somehow add a resistor so that the impedance does not change so much?
Best regards
Best regards
