How to make x-y plot using Pspice?
lcs81
Member level 3
Member level 3
Does any one know what is x-y plot? And is there any one know how to make such plot using Pspice?
Re: X-y plot
I think x-y plot ou mean is for a scope and not in pspice, allowing you to plot two variables versus each other, instead of versus time
Re: X-y plot
u mean can make such plot in spice?
Re: X-y plot
in a usual plot that your parameter is a function of time in schematic window select :plot>> axis settings a window will open choose axis variable then choose the voltage or current of the node you want you should know the name of node or you can name it in pspice by using place net alias before going to change time
Re: X-y plot
you right click on circuit schematics,then choose EDIT SIMULATION CMD.You will have an open window ,you choose DC TRANSFER and specify the input and output.
OR just visit this link below:
https://www.linear.com/solutions/1829
