how to make the ideal CMFB circuit?
yikwon
Newbie level 6
Newbie level 6
I want to know making the ideal CMFB circuit.
I saw that ideal CMFB circuit is made using netlist code in some books as below.
>> ecmfb vcmfb vss poly(4) vb1 o vcmref 0 vop 0 von 0 0 1 -1 0.5 0.5
Can I make the ideal CMFB using VCVS?
please answer about that.
of course you can use vcvs to constitute the cmfb circuit
in fact, vcvs is represented by Exxx in spice
I tried to make ideal CMFB circuit using VCVS but , it's not correct operation.
so, could you show me the ideal CMFB circuit?
refer to this link:
h**p://kabuki.eecs.berkeley.edu/~keitho/ic771ca/pdf/cmfb.pdf
good luck
thank you for your advidce.
I've already read that document. so, i tried to make ideal CMFB refering to the document you said. but, i had the strange results.
*pls, refer to attached file.
compared with opamp using real CMFB circuit, characteristics of the real CMFB is better. i don't understand...
what is my mistakes?
is the output common-mode voltage of your amplifier 0.9V?
yes, common mode voltage is 0.9V
because i use TSMC0.18 process.
that is wrong? i'm a beginner in analog circuit design. need your help.
can you upload your circuit schematic?
that is our opamp architecture.
The ideal CMFB circuit i made don't have any mistake?
if we use that kind of ideal CMFB circuit, the opamp with ideal CMFB have to work corretly. right?
thank you.
your amplifier is a two-stage amplifier, so if your ideal cmfb circuit feeds the voltage to the gate of p-current mirror, your cmfb loop is a positive feedback loop. in order to make the amplifier work, change the polarity of cmfb amplifier vcvs
thank you so much.
I solve the problems from your advice. thank you.
:D
