how to make simulation Ethernet controller in proteus
ragab2010
Junior Member level 1
hi
how to make simulation for Ethernet controller by Proteus by PIC16F877A?
you will need to connect an ethernet controller to that. I think ENC28J60 is there. And you can use TCPIP stack from microchip. I'm not sure if you will be able to use 16f877, it doesn't have sufficient memory to accomodate the code, but may be with the latest stack you can atleast try pinging. Rather if you want to simulate ethernet, go for PIC18 or higher end controllers.
thanks
I want the pic for make this simulation in proteus.. :) more information
I would say start with pic24 or dspic33
you will get a lot of examples online for them and that will help you debug your problems very easily
