how to make Pspice model with the txt file.
Bilal_Ahm
Junior Member level 2
Hi, i need to make a Pspice part for simulation. the Maker company only gives this data.
*Jun 01, 2010 *Doc. ID: 90412, Rev. A *File Name: part irfl9014_PS.txt and part irfl9014_PS.spi *This document is intended as a SPICE modeling guideline and does not *constitute a commercial product data sheet. Designers should refer to the *appropriate data sheet of the same number for guaranteed specification *limits. .SUBCKT irfl9014 1 2 3 ************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** * Model generated on Oct 22, 96 * MODEL FORMAT: SPICE3 * Symmetry POWER MOS Model (Version 1.0) * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=100u W=100u * Default values used in MM: * The voltage-dependent capacitances are * not included. Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM PMOS LEVEL=1 IS=1e-32 +VTO=-3.87971 LAMBDA=0.0503704 KP=0.713612 +CGSO=2.47152e-06 CGDO=1e-11 RS 8 3 0.116837 D1 1 3 MD .MODEL MD D IS=5e-21 RS=0.15039 N=1.5 BV=60 +IBV=10 EG=1.2 XTI=4 TT=1e-07 +CJO=4.40194e-10 VJ=1.63887 M=0.440757 FC=0.5 RDS 3 1 600000 RD 9 1 0.0001 RG 2 7 9.4415 D2 5 4 MD1 * Default values used in MD1: * RS=0 EG=1.11 XTI=3.0 TT=0 * BV=infinite IBV=1mA .MODEL MD1 D IS=1e-32 N=50 +CJO=1.96085e-10 VJ=0.665506 M=0.480463 FC=1e-08 D3 5 0 MD2 * Default values used in MD2: * EG=1.11 XTI=3.0 TT=0 CJO=0 * BV=infinite IBV=1mA .MODEL MD2 D IS=1e-10 N=0.4 RS=3.00002e-06 RL 5 10 1 FI2 7 9 VFI2 -1 VFI2 4 0 0 EV16 10 0 9 7 1 CAP 11 10 6.62636e-10 FI1 7 9 VFI1 -1 VFI1 11 6 0 RCAP 6 10 1 D4 6 0 MD3 * Default values used in MD3: * EG=1.11 XTI=3.0 TT=0 CJO=0 * RS=0 BV=infinite IBV=1mA .MODEL MD3 D IS=1e-10 N=0.4 .ENDS irfl9014
I made a model by model editor.
getting errors. like
INFO(ORPSIM-15423): Unable to find index file irfl9014.ind for library file irfl9014.lib.
INFO(ORPSIM-15422): Making new index file irfl9014.ind for library file irfl9014.lib.
Index has 0 entries from 1 file(s).
ERROR(ORPSIM-15108): Subcircuit IRFL9014 used by X_M1 is undefined
Looks like there is some issue with linking the model.
Also I could see there are no line breaks in the model definition you posted.
Probably the lines defining the subckt are getting treated as comments due to asterisk (*).
Get your model in proper format by breaking the lines.
You can find the complete lines on:
The IRFL9014 file:
  • IRFL9014.rar
thank you so much my problem solved.
thank you so much it helped my problem.
