How to make positive only Gerber files using PSD14.2 ?
totue
Junior Member level 3
i have a big problem with gerber creation because PSD 14.2 create composite layers with negative plots and my pcb manufacturer can't use this type of gerber, he need a positive only gerber files.
Do you now how i can make this with PSD 14.2.
thanks.
Totue :(
psd14.2
Hello,
maybe you should try to use an another output format. This helped me when i had a problem with the output files.
- options->post processing settings
- double click in the row "Device"
- change the output format and maybe you get the correct files
i hope i helps.
greetings,
hqqh
pentalogic + gerber
Thanks but in fact i just need to translate my RS274X files to RS274D files.
Do you have any solution?
Totue.
viewmate
Hello,
sorry, but i dont know how to convert layers between these formats. but if your problem is that you have inverted layers, you can invert they again an get the normal view.
I have used viewmate from pentalogic (a free gerber viewer and editor).
hope it helps,
hqqh
i have find a tool Gerbtool v12 that make this convertion but not with the demo version !!!
Totue.
Re: PSD14.2 gerber
In manufacture > artwork,select the plot mode as positive.
In general parameters select Gerber 6x00
recreate the artwork.
