how to make oscilloscope with laptop
rajaram04
Advanced Member level 3
earth
Hello sir
sir is it possible to make oscilloscope by using my computer or laptop in home ? how its possible ? please explain what to do
sir is there any possibility of hazard to sound card ?
Any PC works on 5v logic voltage. So you have to make sure the input amplitude should not cross 5v. If you are working on circuit with high voltage, use a high value resistors of 1K to 1M ohm, as required. A high value potentiometer can help you to adjust the amplitude.
sir incase of laptop i ve only a mic-in jack so may i proceed with that only ?
Yes. Mic-in is only needed... Make sure you have the audio drivers installed in your PC and it detects the mic port.
They have mentioned in their site to use 1 volt as input. Please go through these FAQ...
http://www.zelscope.com/faq.html
Picoscope is another option. However, as bandwidth requirements rise, price does too and as far as I know the delta with 'discrete' scopes becomes smaller...
