alvays
Member level 4
slew rate simulation
I'm not definitely aware of how to make the slew-rate simulation and fourier analysis.
1)Which method we should choose for slew-rate simulation, open loop or closed loop? If closed loop, should we connect it be voltage follower? And which point we should choose for the result: maximum derivative of output or the slope from 1% to 90% of output? Why?
2)How do we choose the fundamental frequency of fft analysis? What decide it? And should we connect the opamp to be closed loop while fft analysis? What's the usual spec for THD? Why?
Thank you all
Thank you all
