How to make nets on PCB in Protel DTP?
TiMe25
Newbie level 5
Newbie level 5
Pro*el D*P help??
It's possible to make net's in pcb mode. So if i place some footprint's on board can i make net's just with clik on pad's??
TiMe25
Re: Pro*el D*P help??
Hello,
To had net on pcb, just go in DESIGN -> NETLIST -> EDITS NETS.
In this menu you can had or remove net.
CD:)
After you hand route the components, go to the menu item "Design>Netlist>Create Netlist from Connected Copper".
If you are trying to get traces or free pads/vias to pick up the netnames from component pins, use "Design>Netlist>Update Free Primitives From Component Pads".
