how to make my tv anthenna can get many channel??plss answer
Your TV Antennae gets every TV service that is being transmitted, mostly ,at an extremely low signal strength. If your TV service is UHF and the aerial is a yagi, that is a lot of decreasing bars in a line, then the aerial is directional, so if you rotate it there may be other stations available at a reasonable signal strength.
Frank
