thank you for your reply ^^ i would like to make clear, since i couldn't got your ideal clearly ^^
(1) in practical single-ended version of low pass filter is sufficient as long as you keep outputs of VCCS floating as differential outputs.
Question: what's the meaning of "single-ended version of low pass filter is sufficient "? And if i make outputs of VCCS is grounded, is it ok? That is single-ended OTA, not differential OTA.
QS: I saw in your previous message that you use 2 low pass filters to filter the internel "differential" voltage. What I mean is that you are right about doing that, but that's not necessary to maintain differential signaling in internal fictitious nodes.
(2) You probally need another ideal CMFB (balun in spectre) circuit to bias your output common mode voltage
Question: I put my ideal CMFB in the picture, but where should I add this one based on your opinion ? output of VCCS?
Do u mean it is same as Opamp design? I also should add CMFB to the OTA design ?
QS: you can attach your CMFB outputs to inputs of 2 additional common mode VCCS that regulates the common mode of differential outputs to the wanted voltage as long as this high gain loop make your simulator happy to converge.
Thank you very much ^^
[/img]
