saramah
Member level 3
In multiplxing of 2-digit 7-segments disp and to get all two dotpoint(dp) in vetically (i,e. 2nd digit is inverted at 180 degree) pin swaping is made each others.
Further that two digit were bought alongwith pre-made standrad pcb. And the pcb is Common Anode and dot track of its is also interconnected with common point anode.
My question is, I want to make that two DPs flash together at every second without cutting(disconnecting) the tack from common which is alredy connceted with CA point in fabricated pcb??
The xc8, pic887 code is here,
What is understand, If dot's logic is considerd here in seg[] array the it will light up always. as per my openion, my expection can only be fulfil if i cut the track from fabricated pcb from ca track.
Your suggestion please??
tnk u...
//***Define the signal pins of all four displays***//
#define s1 RC0
#define s2 RC1
void main()
unsigned int e,f,g,h; //just variables
int i = 0; //the 2-digit value that is to be displayed
int flag =0; //for creating delay
unsigned int seg[]={0XC0, //Hex value to display the number 0
0XF9, //Hex value to display the number 1
0XA4, //Hex value to display the number 2
0XB0, //Hex value to display the number 3
0X99, //Hex value to display the number 4
0X92, //Hex value to display the number 5
0X82, //Hex value to display the number 6
0XF8, //Hex value to display the number 7
0X80, //Hex value to display the number 8
0X90 //Hex value to display the number 9
}; // dot not incoporated here
//*****I/O Configuration****//
TRISC=0X00;
TRISD=0x00;
PORTC=0XFF;
#define _XTAL_FREQ 20000000
while(1)
//***Splitting "i" into four digits***//
e=d%10; //2nd digit is saved here
f=d/10;
g=f%10; //1st digit is saved here
h=f/10;
PORTD=seg[g];s1=0; //Turn ON display 1 and print 4th digit
__delay_ms(5);s1=1; //Turn OFF display 1 after 5ms delay
PORTD=seg[e];s2=0; //Turn ON display 2 and print 3rd digit
__delay_ms(5);s2=1; //Turn OFF display 2 after 5ms delay
if(flag>=10) //wait
i++;flag=0;
flag++; //increment flag for each flash
tnk u...
