How to make count up ?
Nik Zhafran
Junior Member level 1
Shinjuku-ku, Tokyo, Japan, Japan
Count up 00 to 99
How to make program when each time pattern press it incress one by one ( number 0 then we press pattern it will 1 and press again it be 2 ,press again it be 3 and to 99 )
How to program when i click pushbotton stop it will reset ...
can anyone tuning this code because this code i push the button it increment directly 00 to 99 ... .....
and when click stop it decrement ...
HTML:
        Org    00H
        data_one    equ    P3
        data_ten    equ    P2
        Mynumber    Equ    30H
main_prog:
    MOV    data_ten,#0C0H
        MOV    data_one,#0c0H
        mov    Mynumber,#0
        mov    p1,#0        ;set port 1 as input
        JB     P1.0,up_A
        JB     P1.1,stop_A
        sjmp    main_prog
up_A:   mov    a, Mynumber
        Cjne    A,#99, up
        mov    Mynumber,#0FFH
        sjmp    up
stop_A: mov    a, Mynumber
        Cjne    A,#0, stop
        mov    Mynumber,#99H
        sjmp    stop
up:     inc     Mynumber
        JB    P1.1,stop
        Call    BCD
        call    delay
        mov    a, Mynumber
        Cjne    A,#99, up
        mov    Mynumber,#0FFH
        SJMP    main_prog
stop:   dec     Mynumber
        JB    P1.0,up
        Call    BCD
        call    delay
        mov    a, Mynumber
        Cjne    A,#00, stop
        mov    Mynumber,#100
        SJMP    main_prog
BCD:    Mov     A,Mynumber
        Mov     B,#10
        Div    AB
        call    Seg_conv
        mov    data_ten, A
        mov    A,B
        call    Seg_conv
        mov    data_one, A
        Ret
Seg_conv:    inc     A
        Movc    A, @A+PC
        RET
        DB    0C0H    ; 0
        DB    0F9H    ; 1
        DB    0A4H    ; 2
        DB    0B0H    ; 3
        DB    099H    ; 4
        DB    092H    ; 5
        DB    082H    ; 6
        DB    0F8H    ; 7
        DB    080H    ; 8
        DB    090H    ; 9
delay:  MOV    R5,#0ffh
        MOV    R6,#0ffH
        MOV    R7,#2
delay_loop:    DJNZ    R5,delay_loop
        DJNZ    R6,delay_loop
        DJNZ    R7,delay_loop
        RET
        END
for circuit: connect pin 31 to vcc. reset circuit is not correct. change resistor and capacitor position.
Open Proteus file. Press "Print Screen" button on keyboard. Open mspaint and paste the image and save it. In proteus you can also export the schematic as image file or PDF file. No need to take print out of schematic and scan it and then post it here.
Why are you not using multiplexing for 7 Segment displays ?
you mean change like this
because my lecturer said to use 7 segment for my assignment ....
and i don't know how to program it....
I have try but it just like i said it not work because this code i push the button it increment directly 00 to 99 ... .....
What i want is ....
capacitor -ve should be connected to pin 9 from Vcc and resistor is connected to pin 9 from ground.
step1: initialise i/p and o/p
step2: wait till inc or dec switch pressed
step3: if inc pressed( logic 0 to micro controller) wait till it becomes 1 again (i.e till switch released). increment 'mynumber'. if 'mynumber' is 100, change 'mynumber' to zero. transfer data to seven segment. go to step2.
step4: else if dec pressed, wait till it becomes 1 again. if 'mynumber' is zero change it to 99 else decrement 'mynumber'. transfer data to seven segment. jump to step 2.
rewrite your code according to above format.
I did this so far..
i am so sorry cbecause i dont know much about this ..
HTML:
        Org    00H
	button	equ	0FF28H
        data_one    equ    P3
        data_ten    equ    P2
        mov p0,#40h ;show 0
        mov mainCount,#0
        Mynumber    Equ    30H
main_prog:
    MOV    data_ten,#0C0H
        MOV    data_one,#0c0H
        mov    Mynumber,#0
        JB     P1.0,up_A
        JB     P1.1,stop_A
        sjmp    main_prog
mainloop:
jb p1.0,checkdown
call incRoutine
checkdown:
jb p1.1,display
call decRoutine
display:
call displayRoutine
sjmp mainloop
incRoutine:
inc mainCount
waitInc:
jnb p1.0, waitInc
ret
decRoutine:
dec mainCount
waitdec:
jnb p1.1, waitdec
ret
        Cjne    A,#99, up
        mov    Mynumber,#0FFH
        sjmp    waitInc
        Cjne    A,#0, stop
        mov    Mynumber,#99H
        sjmp    waitInc
up:     inc     Mynumber
        JB    P1.1,stop
        Call    BCD
        call    delay
        mov    a, Mynumber
        Cjne    A,#99, up
        mov    Mynumber,#0FFH
        SJMP    main_prog
stop:   dec     Mynumber
        JB    P1.0,up
        Call    BCD
        call    delay
        mov    a, Mynumber
        Cjne    A,#00, stop
        mov    Mynumber,#100
        SJMP    main_prog
BCD:    Mov     A,Mynumber
        Mov     B,#10
        Div    AB
        call    Seg_conv
        mov    data_ten, A
        mov    A,B
        call    Seg_conv
        mov    data_one, A
        Ret
Seg_conv:    inc     A
        Movc    A, @A+PC
        RET
        DB    0C0H    ; 0
        DB    0F9H    ; 1
        DB    0A4H    ; 2
        DB    0B0H    ; 3
        DB    099H    ; 4
        DB    092H    ; 5
        DB    082H    ; 6
        DB    0F8H    ; 7
        DB    080H    ; 8
        DB    090H    ; 9
delay:  MOV    R5,#0ffh
        MOV    R6,#0ffH
        MOV    R7,#2
        DJNZ    R6,delay_loop
        DJNZ    R7,delay_loop
        RET
        END
Org    00H
        data_one    equ    P3
        data_ten    equ    P2
	IPIN		EQU	P1.0
	DPIN		EQU	P1.1
        Mynumber    Equ    30H
main_prog:
	CALL INIT
AGAIN:
AG2:	JB IPIN,AG1
	CALL DELAY1	;debounce
	JB IPIN,AG1
	JNB IPIN,$	;wait till switch release
	INC MYNUMBER
	mov a,mynumber
	cjne a,#100,pq1
	mov mynumber,#0
pq1:
	call bcd	;diaplay data
AG1:	JB DPIN,AG2
	CALL DELAY1
	JB DPIN,AG2
	JNB DPIN,$
	dec mynumber
	mov a,mynumber
	cjne a,#255,pq2
	mov mynumber,#99
pq2:
	call bcd
	JMP AGAIN
INIT:
	MOV    data_ten,#0C0H
        MOV    data_one,#0c0H
        mov    Mynumber,#0
        mov    p1,#255        ;set port 1 as input BY . IT SHOULD BE 1
RET
DELAY1:	MOV R4,#255
	DJNZ R4,$
RET
BCD:    Mov     A,Mynumber
        Mov     B,#10
        Div    AB
	movc dptr,#seg_conv
	MOVC A,@A+DPTR    ; MOVE DATA @A+DPTR IN A
        mov    data_ten, A
        mov    A,B
        movc dptr,#seg_conv
        mov    data_one, A
Ret
delay:  MOV    R5,#0ffh
        MOV    R6,#0ffH
        MOV    R7,#2
        DJNZ    R6,delay_loop
        DJNZ    R7,delay_loop
        RET
Seg_conv:
	DB    0C0H    ; 0
        DB    0F9H    ; 1
        DB    0A4H    ; 2
        DB    0B0H    ; 3
        DB    099H    ; 4
        DB    092H    ; 5
        DB    082H    ; 6
        DB    0F8H    ; 7
        DB    080H    ; 8
        DB    090H    ; 9
        END
i had not tested this code.
This is the circuit you have to use. It uses multiplexing for 7 Segments. I will soon post a c code and a compiler generated asm code. You make the asm code from it.
Here is working C code which I made. It doesn't use INTx for buttons and Timer interrupts for & Segment displaying. As there is debounce delay for buttons you see flickering when button pressed. If you want flicker free display then I will write one which uses INTx pins for buttons and Timer interrupt for 7 Segment displaying.
mikroC PRO 8051 C Code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
char counter = 0, units, tens;
char ca_mask[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90};
#define SSD_DATA_PORT P2
void main() {
     P0 = 0x00;
     P1 = 0x03;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(1000);
     P2 = 0xFF;
     P1_2_bit = 1;
     P1_3_bit = 1;
     while(1) {
           tens = counter / 10;
           units = counter % 10;
           SSD_DATA_PORT = ca_mask[tens];
           P1_2_bit = 0;
           Delay_ms(10);
           P1_2_bit = 1;
           SSD_DATA_PORT = ca_mask[units];
           P1_3_bit = 0;
           Delay_ms(10);
           P1_3_bit = 1;
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
                if(counter < 99)++counter;
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
                if(counter > 0)--counter;
mikroC PRO 8051 generated assembly code.
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
_main:
        MOV SP+0, #128
;ssd.c,6 ::                 void main() {
;ssd.c,8 ::                 P0 = 0x00;
        MOV P0+0, #0
;ssd.c,9 ::                 P1 = 0x03;
        MOV P1+0, #3
;ssd.c,10 ::                 P2 = 0x00;
        MOV P2+0, #0
;ssd.c,11 ::                 P3 = 0x00;
        MOV P3+0, #0
;ssd.c,13 ::                 Delay_ms(1000);
        MOV R5, 8
        MOV R6, 1
        MOV R7, 245
        DJNZ R7,
        DJNZ R6,
        DJNZ R5,
        NOP
;ssd.c,14 ::                 P2 = 0xFF;
        MOV P2+0, #255
;ssd.c,15 ::                 P1_2_bit = 1;
        SETB P1_2_bit+0
;ssd.c,16 ::                 P1_3_bit = 1;
        SETB P1_3_bit+0
;ssd.c,18 ::                 while(1) {
L_main0:
;ssd.c,20 ::                 tens = counter / 10;
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV R0, A
        MOV _tens+0, 0
;ssd.c,21 ::                 units = counter % 10;
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV _units+0, 0
;ssd.c,23 ::                 SSD_DATA_PORT = ca_mask[tens];
        MOV A, #_ca_mask+0
        ADD A, _tens+0
        MOV R0, A
        MOV P2+0, @R0
;ssd.c,24 ::                 P1_2_bit = 0;
        CLR P1_2_bit+0
;ssd.c,25 ::                 Delay_ms(10);
        MOV R6, 18
        MOV R7, 237
        DJNZ R7,
        DJNZ R6,
;ssd.c,26 ::                 P1_2_bit = 1;
        SETB P1_2_bit+0
;ssd.c,28 ::                 SSD_DATA_PORT = ca_mask[units];
        MOV A, #_ca_mask+0
        ADD A, _units+0
        MOV R0, A
        MOV P2+0, @R0
;ssd.c,29 ::                 P1_3_bit = 0;
        CLR P1_3_bit+0
;ssd.c,30 ::                 Delay_ms(10);
        MOV R6, 18
        MOV R7, 237
        DJNZ R7,
        DJNZ R6,
;ssd.c,31 ::                 P1_3_bit = 1;
        SETB P1_3_bit+0
;ssd.c,33 ::                 if(!P1_0_bit) {
        JB P1_0_bit+0, L_main2
        NOP
;ssd.c,34 ::                 Delay_ms(50);
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
;ssd.c,35 ::                 while(!P1_0_bit);
L_main3:
        JB P1_0_bit+0, L_main4
        NOP
        SJMP L_main3
L_main4:
;ssd.c,36 ::                 if(counter < 99)++counter;
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;ssd.c,37 ::                 }
L_main2:
;ssd.c,39 ::                 if(!P1_1_bit) {
        JB P1_1_bit+0, L_main6
        NOP
;ssd.c,40 ::                 Delay_ms(50);
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
;ssd.c,41 ::                 while(!P1_1_bit);
L_main7:
        JB P1_1_bit+0, L_main8
        NOP
        SJMP L_main7
L_main8:
;ssd.c,42 ::                 if(counter > 0)--counter;
        SETB C
        MOV A, _counter+0
        SUBB A, #0
        JC L_main9
        DEC _counter+0
L_main9:
;ssd.c,43 ::                 }
L_main6:
;ssd.c,45 ::                 }
        LJMP L_main0
;ssd.c,46 ::                 }
        SJMP #254
; end of _main
  • AT89C51 7 Segment Driving.rar
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
void main() {
     P0 = 0x00;
     P1 = 0x03;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(1000);
     P2 = 0xFF;
     P1_2_bit = 1;
     P1_3_bit = 1;
     while(1) {
           P1_2_bit = 0;
           Delay_ms(10);
           P1_2_bit = 1;
           P1_3_bit = 0;
           Delay_ms(10);
           P1_3_bit = 1;
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
_main:
        MOV SP+0, #128
        MOV P0+0, #0
        MOV P1+0, #3
        MOV P2+0, #0
        MOV P3+0, #0
        MOV R5, 8
        MOV R6, 1
        MOV R7, 245
        DJNZ R7,
        DJNZ R6,
        DJNZ R5,
        NOP
        MOV P2+0, #255
        SETB P1_2_bit+0
        SETB P1_3_bit+0
L_main0:
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV R0, A
        MOV _tens+0, 0
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV _units+0, 0
        MOV A, #_ca_mask+0
        ADD A, _tens+0
        MOV R0, A
        MOV P2+0, @R0
        CLR P1_2_bit+0
        MOV R6, 18
        MOV R7, 237
        DJNZ R7,
        DJNZ R6,
        SETB P1_2_bit+0
        MOV A, #_ca_mask+0
        ADD A, _units+0
        MOV R0, A
        MOV P2+0, @R0
        CLR P1_3_bit+0
        MOV R6, 18
        MOV R7, 237
        DJNZ R7,
        DJNZ R6,
        SETB P1_3_bit+0
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main3:
        NOP
        SJMP L_main3
L_main4:
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;ssd.c,37 ::                 }
L_main2:
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main7:
        NOP
        SJMP L_main7
L_main8:
        SETB C
        MOV A, _counter+0
        SUBB A, #0
        JC L_main9
        DEC _counter+0
L_main9:
;ssd.c,43 ::                 }
L_main6:
;ssd.c,45 ::                 }
        LJMP L_main0
;ssd.c,46 ::                 }
        SJMP #254
; end of _main
dear milan, the author is beginner. multiplexing is complex. for his present work no flickering problem will come. as seven segment is individually drived.
@welove8051
Ok.
Here is the new circuit and new C and asm codes.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
#define SSD_DATA_PORT_UNITS P3
#define SSD_DATA_PORT_TENS P2
void main() {
     P0 = 0x00;
     P1 = 0x03;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(1000);
     P2 = 0xFF;
     while(1) {
           SSD_DATA_PORT_UNITS = ca_mask[units];
           SSD_DATA_PORT_TENS = ca_mask[tens];
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
_main:
        MOV SP+0, #128
;ssd.c,7 ::                 void main() {
;ssd.c,9 ::                 P0 = 0x00;
        MOV P0+0, #0
;ssd.c,10 ::                 P1 = 0x03;
        MOV P1+0, #3
;ssd.c,11 ::                 P2 = 0x00;
        MOV P2+0, #0
;ssd.c,12 ::                 P3 = 0x00;
        MOV P3+0, #0
;ssd.c,14 ::                 Delay_ms(1000);
        MOV R5, 8
        MOV R6, 1
        MOV R7, 245
        DJNZ R7,
        DJNZ R6,
        DJNZ R5,
        NOP
;ssd.c,15 ::                 P2 = 0xFF;
        MOV P2+0, #255
;ssd.c,17 ::                 while(1) {
L_main0:
;ssd.c,19 ::                 tens = counter / 10;
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV R0, A
        MOV _tens+0, 0
;ssd.c,20 ::                 units = counter % 10;
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV _units+0, 0
;ssd.c,22 ::                 SSD_DATA_PORT_UNITS = ca_mask[units];
        MOV A, #_ca_mask+0
        ADD A, R0
        MOV R0, A
        MOV P3+0, @R0
;ssd.c,23 ::                 SSD_DATA_PORT_TENS = ca_mask[tens];
        MOV A, #_ca_mask+0
        ADD A, _tens+0
        MOV R0, A
        MOV P2+0, @R0
;ssd.c,25 ::                 if(!P1_0_bit) {
        NOP
;ssd.c,26 ::                 Delay_ms(50);
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
;ssd.c,27 ::                 while(!P1_0_bit);
L_main3:
        NOP
        SJMP L_main3
L_main4:
;ssd.c,28 ::                 if(counter < 99)++counter;
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;ssd.c,29 ::                 }
L_main2:
;ssd.c,31 ::                 if(!P1_1_bit) {
        NOP
;ssd.c,32 ::                 Delay_ms(50);
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
;ssd.c,33 ::                 while(!P1_1_bit);
L_main7:
        NOP
        SJMP L_main7
L_main8:
;ssd.c,34 ::                 if(counter > 0)--counter;
        SETB C
        MOV A, _counter+0
        SUBB A, #0
        JC L_main9
        DEC _counter+0
L_main9:
;ssd.c,35 ::                 }
L_main6:
;ssd.c,37 ::                 }
        SJMP L_main0
;ssd.c,38 ::                 }
        SJMP #254
; end of _main
List file
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
;  LST file generated by mikroListExporter - v.2.0
; Date/Time: 2/25/2015 4:15:17 PM
;Address Opcode         ASM
0x0000  0x02002E        LJMP 46
0x0003  0x020000        LJMP 0
0x0006  0x00            NOP
0x0007  0x00            NOP
0x0008  0x00            NOP
0x0009  0x00            NOP
0x000A  0x00            NOP
0x000B  0x020000        LJMP 0
0x000E  0x00            NOP
0x000F  0x00            NOP
0x0010  0x00            NOP
0x0011  0x00            NOP
0x0012  0x00            NOP
0x0013  0x020000        LJMP 0
0x0016  0x00            NOP
0x0017  0x00            NOP
0x0018  0x00            NOP
0x0019  0x00            NOP
0x001A  0x00            NOP
0x001B  0x020000        LJMP 0
0x001E  0x00            NOP
0x001F  0x00            NOP
0x0020  0x00            NOP
0x0021  0x00            NOP
0x0022  0x00            NOP
0x0023  0x020000        LJMP 0
___CC2D:
;__Lib_System.c,13 ::
;__Lib_System.c,15 ::
_CC2D_Loop1:
;__Lib_System.c,16 ::
0x0026  0xE4            CLR A
;__Lib_System.c,17 ::
0x0027  0x93            MOVC A, @A+DPTR
;__Lib_System.c,18 ::
0x0028  0xF6            MOV @R0, A
;__Lib_System.c,19 ::
0x0029  0x08            INC R0
;__Lib_System.c,20 ::
0x002A  0xA3            INC DPTR
;__Lib_System.c,21 ::
0x002B  0xD9F9          DJNZ R1, _CC2D_Loop1
;__Lib_System.c,23 ::
0x002D  0x22            RET
; end of ___CC2D
_main:
0x002E  0x75813B        MOV SP, #59
0x0031  0x1200B4        LCALL 180
0x0034  0x758000        MOV P0, #0
0x0037  0x759003        MOV P1, #3
0x003A  0x75A000        MOV P2, #0
0x003D  0x75B000        MOV P3, #0
0x0040  0x7D08          MOV R5, 8
0x0042  0x7E01          MOV R6, 1
0x0044  0x7FF5          MOV R7, 245
0x0046  0xDFFE          DJNZ R7, PC-2
0x0048  0xDEFC          DJNZ R6, PC-4
0x004A  0xDDFA          DJNZ R5, PC-6
0x004C  0x00            NOP
0x004D  0x75A0FF        MOV P2, #255
L_main0:
0x0050  0x75F00A        MOV B, #10
0x0053  0xE53A          MOV A, _counter
0x0055  0x84            DIV AB
0x0056  0xF8            MOV R0, A
0x0057  0x850009        MOV _tens, 0
0x005A  0x75F00A        MOV B, #10
0x005D  0xE53A          MOV A, _counter
0x005F  0x84            DIV AB
0x0060  0xE5F0          MOV A, B
0x0062  0xF8            MOV R0, A
0x0063  0x850008        MOV _units, 0
0x0066  0x7430          MOV A, lo_addr(_ca_mask)
0x0068  0x28            ADD A, R0
0x0069  0xF8            MOV R0, A
0x006A  0x86B0          MOV P3, @R0
0x006C  0x7430          MOV A, lo_addr(_ca_mask)
0x006E  0x2509          ADD A, _tens
0x0070  0xF8            MOV R0, A
0x0071  0x86A0          MOV P2, @R0
0x0073  0x209016        JB P1_0_bit, L_main2
0x0076  0x7E5A          MOV R6, 90
0x0078  0x7FA5          MOV R7, 165
0x007A  0xDFFE          DJNZ R7, PC-2
0x007C  0xDEFC          DJNZ R6, PC-4
L_main3:
0x007E  0x209002        JB P1_0_bit, L_main4
0x0081  0x80FB          SJMP L_main3
L_main4:
0x0083  0xC3            CLR C
0x0084  0xE53A          MOV A, _counter
0x0086  0x9463          SUBB A, #99
0x0088  0x5002          JNC L_main5
0x008A  0x053A          INC _counter
L_main5:
;ssd.c,29 ::            }
L_main2:
0x008C  0x209116        JB P1_1_bit, L_main6
0x008F  0x7E5A          MOV R6, 90
0x0091  0x7FA5          MOV R7, 165
0x0093  0xDFFE          DJNZ R7, PC-2
0x0095  0xDEFC          DJNZ R6, PC-4
L_main7:
0x0097  0x209102        JB P1_1_bit, L_main8
0x009A  0x80FB          SJMP L_main7
L_main8:
0x009C  0xD3            SETB C
0x009D  0xE53A          MOV A, _counter
0x009F  0x9400          SUBB A, #0
0x00A1  0x4002          JC L_main9
0x00A3  0x153A          DEC _counter
L_main9:
;ssd.c,35 ::            }
L_main6:
;ssd.c,37 ::            }
0x00A5  0x80A9          SJMP L_main0
;ssd.c,38 ::            }
0x00A7  0x80FE          SJMP #254
; end of _main
0x00B4  0x7830          MOV R0, 48
0x00B6  0x790B          MOV R1, 11
0x00B8  0x7582A9        MOV DPL, 169
0x00BB  0x758300        MOV DPH, 0
0x00BE  0x120026        LCALL 38
0x00C1  0x22            RET
;ssd.c,0 :: ?ICS_ca_mask
0x00A9  0xC0F9A4 ;?ICS_ca_mask+0
0x00AC  0xB09992 ;?ICS_ca_mask+3
0x00AF  0x82F880 ;?ICS_ca_mask+6
0x00B2  0x90 ;?ICS_ca_mask+9
; end of ?ICS_ca_mask
;ssd.c,0 :: ?ICS_counter
0x00B3  0x00 ;?ICS_counter+0
; end of ?ICS_counter
Symbol List:
//** Routines locations **
//ADDRESS    SIZE    PROCEDURE
0x0026       [8]    ___CC2D
0x002E     [123]    _main
//** Variables locations **
//ADDRESS    SIZE    VARIABLE
0x0000       [1]    R0
0x0001       [1]    R1
0x0002       [1]    R2
0x0003       [1]    R3
0x0004       [1]    R4
0x0005       [1]    R5
0x0006       [1]    R6
0x0007       [1]    R7
0x0008       [1]    _units
0x0009       [1]    _tens
0x0030      [10]    _ca_mask
0x003A       [1]    _counter
0x0080       [1]    P0
0x0080       [0]    P0_6_bit
0x0080       [0]    P0_5_bit
0x0080       [0]    P0_0_bit
0x0080       [0]    P0_1_bit
0x0080       [0]    P0_2_bit
0x0080       [0]    P0_3_bit
0x0080       [0]    P0_4_bit
0x0080       [0]    P0_7_bit
0x0081       [1]    SP
0x0082       [1]    DPL
0x0082       [2]    DPTR
0x0082       [1]    DP0L
0x0083       [1]    DPH
0x0083       [1]    DP0H
0x0084       [1]    DP1L
0x0085       [1]    DP1H
0x0087       [0]    SMOD_bit
0x0087       [0]    GF1_bit
0x0087       [1]    PCON
0x0087       [0]    PD_bit
0x0087       [0]    IDL_bit
0x0087       [0]    GF0_bit
0x0088       [0]    IT1_bit
0x0088       [0]    TF1_bit
0x0088       [0]    TR0_bit
0x0088       [0]    IE1_bit
0x0088       [0]    TF0_bit
0x0088       [0]    TR1_bit
0x0088       [1]    TCON
0x0088       [0]    IT0_bit
0x0088       [0]    IE0_bit
0x0089       [0]    M11_bit
0x0089       [0]    C_T1_bit
0x0089       [0]    GATE1_bit
0x0089       [0]    M01_bit
0x0089       [0]    M00_bit
0x0089       [1]    TMOD
0x0089       [0]    M10_bit
0x0089       [0]    GATE0_bit
0x0089       [0]    C_T0_bit
0x008A       [1]    TL0
0x008B       [1]    TL1
0x008C       [1]    TH0
0x008D       [1]    TH1
0x008E       [0]    DISRTO_bit
0x008E       [0]    WDIDLE_bit
0x008E       [0]    EXTRAM_bit
0x008E       [1]    AUXR
0x008E       [0]    DISALE_bit
0x0090       [0]    P1_1_bit
0x0090       [0]    P1_2_bit
0x0090       [1]    P1
0x0090       [0]    P1_0_bit
0x0090       [0]    P1_3_bit
0x0090       [0]    P1_6_bit
0x0090       [0]    P1_7_bit
0x0090       [0]    P1_4_bit
0x0090       [0]    P1_5_bit
0x0098       [0]    REN_bit
0x0098       [0]    TB8_bit
0x0098       [0]    RB8_bit
0x0098       [0]    SM1_bit
0x0098       [0]    SM0_bit
0x0098       [0]    SM2_bit
0x0098       [0]    RI_bit
0x0098       [1]    SCON
0x0098       [0]    TI_bit
0x0099       [1]    SBUF
0x00A0       [0]    P2_2_bit
0x00A0       [0]    P2_3_bit
0x00A0       [1]    P2
0x00A0       [0]    P2_0_bit
0x00A0       [0]    P2_1_bit
0x00A0       [0]    P2_7_bit
0x00A0       [0]    P2_6_bit
0x00A0       [0]    P2_4_bit
0x00A0       [0]    P2_5_bit
0x00A2       [0]    DPS_bit
0x00A2       [1]    AUXR1
0x00A6       [1]    WDTRST
0x00A8       [0]    ET0_bit
0x00A8       [0]    ET1_bit
0x00A8       [1]    IE
0x00A8       [0]    EX1_bit
0x00A8       [0]    EX0_bit
0x00A8       [0]    EA_bit
0x00A8       [0]    ES_bit
0x00B0       [0]    P3_1_bit
0x00B0       [1]    P3
0x00B0       [0]    P3_0_bit
0x00B0       [0]    P3_5_bit
0x00B0       [0]    P3_6_bit
0x00B0       [0]    P3_7_bit
0x00B0       [0]    P3_2_bit
0x00B0       [0]    P3_3_bit
0x00B0       [0]    P3_4_bit
0x00B8       [0]    PT0_bit
0x00B8       [0]    PX0_bit
0x00B8       [1]    IP
0x00B8       [0]    PS_bit
0x00B8       [0]    PT1_bit
0x00B8       [0]    PX1_bit
0x00D0       [0]    RS1_bit
0x00D0       [0]    RS0_bit
0x00D0       [0]    F0_bit
0x00D0       [0]    CY_bit
0x00D0       [0]    AC_bit
0x00D0       [0]    OV_bit
0x00D0       [1]    PSW
0x00D0       [0]    P_bit
0x00D0       [0]    F1_bit
0x00E0       [1]    ACC
0x00F0       [1]    B
//** Constants locations **
//ADDRESS    SIZE    CONSTANT
0x00A9      [10]    ?ICS_ca_mask
0x00B3       [1]    ?ICS_counter
//** Label List: **
  L_main0
  L_main1
  L_main2
  L_main3
  L_main4
  L_main5
  L_main6
  L_main7
  L_main8
  L_main9
  _main
  _CC2D_Loop1
  _CC2PD_Loop1
  _CC2XD_Loop1
  ___DoIFC
  ___CC2D
  ___CC2PD
  ___CC2XD
  • AT89C51 SSD.rar
while(1) {
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
dear milan, it doesnt have rounding up. that is when counter reaches 99 or 0.
What do you mean by rounding up ? You mean after 99 if increment is pressed it should become 0 ?
Both lines are missing an else statement. I'm sure you can figure it out!
I think his requirement is if button is pressed it should increment from 0 to 99 and stop and if button 2 is pressed it should reset and become 0.
@Nik Zhafran
What is your exact requirement.
I belive you are right, just my ignorance. Reviewing the first post, the code is missing keypress (edge) detection. This is accomplished by a combination of debounce, as with delay_ms(50), and a compare of present and previous state.
Symbolically
if  (present_state & KEY_XX && !(previos_state & KEY_XX))
  count++
previous_state = present_state;
Code as per requirement in post #1.
C Code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
void main() {
     P0 = 0x00;
     P1 = 0x03;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(1000);
     P2 = 0xFF;
     while(1) {
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
                counter = 0;
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
_main:
        MOV SP+0, #128
        MOV P0+0, #0
        MOV P1+0, #3
        MOV P2+0, #0
        MOV P3+0, #0
        MOV R5, 8
        MOV R6, 1
        MOV R7, 245
        DJNZ R7,
        DJNZ R6,
        DJNZ R5,
        NOP
        MOV P2+0, #255
L_main0:
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV R0, A
        MOV _tens+0, 0
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV _units+0, 0
        MOV A, #_ca_mask+0
        ADD A, R0
        MOV R0, A
        MOV P3+0, @R0
        MOV A, #_ca_mask+0
        ADD A, _tens+0
        MOV R0, A
        MOV P2+0, @R0
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main3:
        NOP
        SJMP L_main3
L_main4:
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;ssd.c,29 ::                 }
L_main2:
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main7:
        NOP
        SJMP L_main7
L_main8:
;ssd.c,34 ::                 counter = 0;
        MOV _counter+0, #0
;ssd.c,35 ::                 }
L_main6:
;ssd.c,36 ::                 }
        SJMP L_main0
;ssd.c,37 ::                 }
        SJMP #254
; end of _main
List file
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
; Date/Time: 2/25/2015 10:37:22 PM
;Address Opcode         ASM
0x0006  0x00            NOP
0x0007  0x00            NOP
0x0008  0x00            NOP
0x0009  0x00            NOP
0x000A  0x00            NOP
0x000E  0x00            NOP
0x000F  0x00            NOP
0x0010  0x00            NOP
0x0011  0x00            NOP
0x0012  0x00            NOP
0x0016  0x00            NOP
0x0017  0x00            NOP
0x0018  0x00            NOP
0x0019  0x00            NOP
0x001A  0x00            NOP
0x001E  0x00            NOP
0x001F  0x00            NOP
0x0020  0x00            NOP
0x0021  0x00            NOP
0x0022  0x00            NOP
___CC2D:
_CC2D_Loop1:
0x0026  0xE4            CLR A
0x0029  0x08            INC R0
0x002D  0x22            RET
; end of ___CC2D
_main:
0x0031  0x1200AE        LCALL 174
0x004C  0x00            NOP
L_main0:
0x0055  0x84            DIV AB
0x005F  0x84            DIV AB
L_main3:
L_main4:
0x0083  0xC3            CLR C
L_main5:
;ssd.c,29 ::            }
L_main2:
0x008C  0x209110        JB P1_1_bit, L_main6
L_main7:
L_main8:
0x009C  0x753A00        MOV _counter, #0
;ssd.c,35 ::            }
L_main6:
;ssd.c,36 ::            }
0x009F  0x80AF          SJMP L_main0
;ssd.c,37 ::            }
0x00A1  0x80FE          SJMP #254
; end of _main
0x00AE  0x7830          MOV R0, 48
0x00B0  0x790B          MOV R1, 11
0x00B2  0x7582A3        MOV DPL, 163
0x00B5  0x758300        MOV DPH, 0
0x00B8  0x120026        LCALL 38
0x00BB  0x22            RET
0x00A3  0xC0F9A4 ;?ICS_ca_mask+0
0x00A6  0xB09992 ;?ICS_ca_mask+3
0x00A9  0x82F880 ;?ICS_ca_mask+6
0x00AC  0x90 ;?ICS_ca_mask+9
0x00AD  0x00 ;?ICS_counter+0
Symbol List:
0x0026       [8]    ___CC2D
0x002E     [117]    _main
0x0000       [1]    R0
0x0001       [1]    R1
0x0002       [1]    R2
0x0003       [1]    R3
0x0004       [1]    R4
0x0005       [1]    R5
0x0006       [1]    R6
0x0007       [1]    R7
0x0008       [1]    _units
0x0009       [1]    _tens
0x003A       [1]    _counter
0x0080       [1]    P0
0x0080       [0]    P0_6_bit
0x0080       [0]    P0_5_bit
0x0080       [0]    P0_0_bit
0x0080       [0]    P0_1_bit
0x0080       [0]    P0_2_bit
0x0080       [0]    P0_3_bit
0x0080       [0]    P0_4_bit
0x0080       [0]    P0_7_bit
0x0081       [1]    SP
0x0082       [1]    DPL
0x0082       [2]    DPTR
0x0082       [1]    DP0L
0x0083       [1]    DPH
0x0083       [1]    DP0H
0x0084       [1]    DP1L
0x0085       [1]    DP1H
0x0087       [0]    SMOD_bit
0x0087       [0]    GF1_bit
0x0087       [1]    PCON
0x0087       [0]    PD_bit
0x0087       [0]    IDL_bit
0x0087       [0]    GF0_bit
0x0088       [0]    IT1_bit
0x0088       [0]    TF1_bit
0x0088       [0]    TR0_bit
0x0088       [0]    IE1_bit
0x0088       [0]    TF0_bit
0x0088       [0]    TR1_bit
0x0088       [1]    TCON
0x0088       [0]    IT0_bit
0x0088       [0]    IE0_bit
0x0089       [0]    M11_bit
0x0089       [0]    C_T1_bit
0x0089       [0]    M01_bit
0x0089       [0]    M00_bit
0x0089       [1]    TMOD
0x0089       [0]    M10_bit
0x0089       [0]    C_T0_bit
0x008A       [1]    TL0
0x008B       [1]    TL1
0x008C       [1]    TH0
0x008D       [1]    TH1
0x008E       [1]    AUXR
0x0090       [0]    P1_1_bit
0x0090       [0]    P1_2_bit
0x0090       [1]    P1
0x0090       [0]    P1_0_bit
0x0090       [0]    P1_3_bit
0x0090       [0]    P1_6_bit
0x0090       [0]    P1_7_bit
0x0090       [0]    P1_4_bit
0x0090       [0]    P1_5_bit
0x0098       [0]    REN_bit
0x0098       [0]    TB8_bit
0x0098       [0]    RB8_bit
0x0098       [0]    SM1_bit
0x0098       [0]    SM0_bit
0x0098       [0]    SM2_bit
0x0098       [0]    RI_bit
0x0098       [1]    SCON
0x0098       [0]    TI_bit
0x0099       [1]    SBUF
0x00A0       [0]    P2_3_bit
0x00A0       [0]    P2_4_bit
0x00A0       [0]    P2_1_bit
0x00A0       [0]    P2_2_bit
0x00A0       [0]    P2_0_bit
0x00A0       [1]    P2
0x00A0       [0]    P2_7_bit
0x00A0       [0]    P2_5_bit
0x00A0       [0]    P2_6_bit
0x00A2       [1]    AUXR1
0x00A2       [0]    DPS_bit
0x00A6       [1]    WDTRST
0x00A8       [0]    EX1_bit
0x00A8       [1]    IE
0x00A8       [0]    ET0_bit
0x00A8       [0]    ET1_bit
0x00A8       [0]    EX0_bit
0x00A8       [0]    EA_bit
0x00A8       [0]    ES_bit
0x00B0       [0]    P3_0_bit
0x00B0       [1]    P3
0x00B0       [0]    P3_1_bit
0x00B0       [0]    P3_5_bit
0x00B0       [0]    P3_6_bit
0x00B0       [0]    P3_7_bit
0x00B0       [0]    P3_2_bit
0x00B0       [0]    P3_3_bit
0x00B0       [0]    P3_4_bit
0x00B8       [0]    PT0_bit
0x00B8       [0]    PX0_bit
0x00B8       [1]    IP
0x00B8       [0]    PS_bit
0x00B8       [0]    PT1_bit
0x00B8       [0]    PX1_bit
0x00D0       [0]    RS1_bit
0x00D0       [0]    RS0_bit
0x00D0       [0]    F0_bit
0x00D0       [0]    CY_bit
0x00D0       [0]    AC_bit
0x00D0       [0]    OV_bit
0x00D0       [1]    PSW
0x00D0       [0]    P_bit
0x00D0       [0]    F1_bit
0x00E0       [1]    ACC
0x00F0       [1]    B
0x00A3      [10]    ?ICS_ca_mask
0x00AD       [1]    ?ICS_counter
//** Label List: **
  L_main0
  L_main1
  L_main2
  L_main3
  L_main4
  L_main5
  L_main6
  L_main7
  L_main8
  _main
  _CC2D_Loop1
  _CC2PD_Loop1
  _CC2XD_Loop1
  ___DoIFC
  ___CC2D
  ___CC2PD
  ___CC2XD
@Nik Zhafran
sorry i late because i have many assignment to finish it
ermm yes i want button pattern (p1.0) is pressed it should increment from 0 to 99 and stop and if button stop(p1.1) is pressed it should reset and become 0.
Org    00H
        data_one    equ    P3
        data_ten    equ    P2
	IPIN		EQU	P1.0
	DPIN		EQU	P1.1
        Mynumber    Equ    30H
main_prog:
	CALL INIT
AGAIN:
AG2:	JB IPIN,AG1
	JB IPIN,AG1
	INC MYNUMBER
	mov a,mynumber
	cjne a,#100,pq1
	mov mynumber,#0
pq1:
AG1:	JB DPIN,AG2
	CALL DELAY1
	JB DPIN,AG2
	JNB DPIN,$
	dec mynumber
	mov a,mynumber
	cjne a,#255,pq2
	mov mynumber,#99
pq2:
	call bcd
	JMP AGAIN
INIT:
	MOV    data_ten,#0C0H
        MOV    data_one,#0c0H
        mov    Mynumber,#0
RET
DELAY1:	MOV R4,#255
	DJNZ R4,$
RET
BCD:    Mov     A,Mynumber
        Mov     B,#10
        Div    AB
	movc dptr,#seg_conv
        mov    data_ten, A
        mov    A,B
        movc dptr,#seg_conv
        mov    data_one, A
Ret
delay:  MOV    R5,#0ffh
        MOV    R6,#0ffH
        MOV    R7,#2
        DJNZ    R6,delay_loop
        DJNZ    R7,delay_loop
        RET
Seg_conv:
	DB    0C0H    ; 0
        DB    0F9H    ; 1
        DB    0A4H    ; 2
        DB    0B0H    ; 3
        DB    099H    ; 4
        DB    092H    ; 5
        DB    082H    ; 6
        DB    0F8H    ; 7
        DB    080H    ; 8
        DB    090H    ; 9
        END
when i click translate current file is show error that 2 line code...
movc dptr,#seg_conv
C Code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
void main() {
     P0 = 0x00;
     P1 = 0x03;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(1000);
     P2 = 0xFF;
     while(1) {
           if(!P1_0_bit) {
                Delay_ms(50);
                while(!P1_0_bit);
           if(!P1_1_bit) {
                Delay_ms(50);
                while(!P1_1_bit);
                counter = 0;
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
_main:
        MOV SP+0, #128
        MOV P0+0, #0
        MOV P1+0, #3
        MOV P2+0, #0
        MOV P3+0, #0
        MOV R5, 8
        MOV R6, 1
        MOV R7, 245
        DJNZ R7,
        DJNZ R6,
        DJNZ R5,
        NOP
        MOV P2+0, #255
L_main0:
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV R0, A
        MOV _tens+0, 0
        MOV B+0, #10
        MOV A, _counter+0
        DIV AB
        MOV A, B+0
        MOV R0, A
        MOV _units+0, 0
        MOV A, #_ca_mask+0
        ADD A, R0
        MOV R0, A
        MOV P3+0, @R0
        MOV A, #_ca_mask+0
        ADD A, _tens+0
        MOV R0, A
        MOV P2+0, @R0
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main3:
        NOP
        SJMP L_main3
L_main4:
        CLR C
        MOV A, _counter+0
        SUBB A, #99
        JNC L_main5
        INC _counter+0
L_main5:
;ssd.c,29 ::                 }
L_main2:
        NOP
        MOV R6, 90
        MOV R7, 165
        DJNZ R7,
        DJNZ R6,
L_main7:
        NOP
        SJMP L_main7
L_main8:
        MOV _counter+0, #0
;ssd.c,35 ::                 }
L_main6:
;ssd.c,36 ::                 }
        SJMP L_main0
;ssd.c,37 ::                 }
        SJMP #254
; end of _main
List file
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
;Address Opcode         ASM
0x0006  0x00            NOP
0x0007  0x00            NOP
0x0008  0x00            NOP
0x0009  0x00            NOP
0x000A  0x00            NOP
0x000E  0x00            NOP
0x000F  0x00            NOP
0x0010  0x00            NOP
0x0011  0x00            NOP
0x0012  0x00            NOP
0x0016  0x00            NOP
0x0017  0x00            NOP
0x0018  0x00            NOP
0x0019  0x00            NOP
0x001A  0x00            NOP
0x001E  0x00            NOP
0x001F  0x00            NOP
0x0020  0x00            NOP
0x0021  0x00            NOP
0x0022  0x00            NOP
___CC2D:
_CC2D_Loop1:
0x0026  0xE4            CLR A
0x0029  0x08            INC R0
0x002D  0x22            RET
; end of ___CC2D
_main:
0x004C  0x00            NOP
L_main0:
0x0055  0x84            DIV AB
0x005F  0x84            DIV AB
L_main3:
L_main4:
0x0083  0xC3            CLR C
L_main5:
;ssd.c,29 ::            }
L_main2:
L_main7:
L_main8:
;ssd.c,35 ::            }
L_main6:
;ssd.c,36 ::            }
;ssd.c,37 ::            }
; end of _main
0x00BB  0x22            RET
Symbol List:
0x0026       [8]    ___CC2D
0x002E     [117]    _main
0x0000       [1]    R0
0x0001       [1]    R1
0x0002       [1]    R2
0x0003       [1]    R3
0x0004       [1]    R4
0x0005       [1]    R5
0x0006       [1]    R6
0x0007       [1]    R7
0x0008       [1]    _units
0x0009       [1]    _tens
0x003A       [1]    _counter
0x0080       [1]    P0
0x0080       [0]    P0_6_bit
0x0080       [0]    P0_5_bit
0x0080       [0]    P0_0_bit
0x0080       [0]    P0_1_bit
0x0080       [0]    P0_2_bit
0x0080       [0]    P0_3_bit
0x0080       [0]    P0_4_bit
0x0080       [0]    P0_7_bit
0x0081       [1]    SP
0x0082       [1]    DPL
0x0082       [2]    DPTR
0x0082       [1]    DP0L
0x0083       [1]    DPH
0x0083       [1]    DP0H
0x0084       [1]    DP1L
0x0085       [1]    DP1H
0x0087       [0]    SMOD_bit
0x0087       [0]    GF1_bit
0x0087       [1]    PCON
0x0087       [0]    PD_bit
0x0087       [0]    IDL_bit
0x0087       [0]    GF0_bit
0x0088       [0]    IT1_bit
0x0088       [0]    TF1_bit
0x0088       [0]    TR0_bit
0x0088       [0]    IE1_bit
0x0088       [0]    TF0_bit
0x0088       [0]    TR1_bit
0x0088       [1]    TCON
0x0088       [0]    IT0_bit
0x0088       [0]    IE0_bit
0x0089       [0]    M11_bit
0x0089       [0]    C_T1_bit
0x0089       [0]    M01_bit
0x0089       [0]    M00_bit
0x0089       [1]    TMOD
0x0089       [0]    M10_bit
0x0089       [0]    C_T0_bit
0x008A       [1]    TL0
0x008B       [1]    TL1
0x008C       [1]    TH0
0x008D       [1]    TH1
0x008E       [1]    AUXR
0x0090       [0]    P1_1_bit
0x0090       [0]    P1_2_bit
0x0090       [1]    P1
0x0090       [0]    P1_0_bit
0x0090       [0]    P1_3_bit
0x0090       [0]    P1_6_bit
0x0090       [0]    P1_7_bit
0x0090       [0]    P1_4_bit
0x0090       [0]    P1_5_bit
0x0098       [0]    REN_bit
0x0098       [0]    TB8_bit
0x0098       [0]    RB8_bit
0x0098       [0]    SM1_bit
0x0098       [0]    SM0_bit
0x0098       [0]    SM2_bit
0x0098       [0]    RI_bit
0x0098       [1]    SCON
0x0098       [0]    TI_bit
0x0099       [1]    SBUF
0x00A0       [0]    P2_3_bit
0x00A0       [0]    P2_4_bit
0x00A0       [0]    P2_1_bit
0x00A0       [0]    P2_2_bit
0x00A0       [0]    P2_0_bit
0x00A0       [1]    P2
0x00A0       [0]    P2_7_bit
0x00A0       [0]    P2_5_bit
0x00A0       [0]    P2_6_bit
0x00A2       [1]    AUXR1
0x00A2       [0]    DPS_bit
0x00A6       [1]    WDTRST
0x00A8       [0]    EX1_bit
0x00A8       [1]    IE
0x00A8       [0]    ET0_bit
0x00A8       [0]    ET1_bit
0x00A8       [0]    EX0_bit
0x00A8       [0]    EA_bit
0x00A8       [0]    ES_bit
0x00B0       [0]    P3_0_bit
0x00B0       [1]    P3
0x00B0       [0]    P3_1_bit
0x00B0       [0]    P3_5_bit
0x00B0       [0]    P3_6_bit
0x00B0       [0]    P3_7_bit
0x00B0       [0]    P3_2_bit
0x00B0       [0]    P3_3_bit
0x00B0       [0]    P3_4_bit
0x00B8       [0]    PT0_bit
0x00B8       [0]    PX0_bit
0x00B8       [1]    IP
0x00B8       [0]    PS_bit
0x00B8       [0]    PT1_bit
0x00B8       [0]    PX1_bit
0x00D0       [0]    RS1_bit
0x00D0       [0]    RS0_bit
0x00D0       [0]    F0_bit
0x00D0       [0]    CY_bit
0x00D0       [0]    AC_bit
0x00D0       [0]    OV_bit
0x00D0       [1]    PSW
0x00D0       [0]    P_bit
0x00D0       [0]    F1_bit
0x00E0       [1]    ACC
0x00F0       [1]    B
//** Label List: **
  L_main0
  L_main1
  L_main2
  L_main3
  L_main4
  L_main5
  L_main6
  L_main7
  L_main8
  _main
  _CC2D_Loop1
  _CC2PD_Loop1
  _CC2XD_Loop1
  ___DoIFC
  ___CC2D
  ___CC2PD
  ___CC2XD
ermmm it ok for not use org 00h and end ?
sorry because i new learn about micro...
Sorry, I don't program in asm. The asm I posted is generated by mikroC PRO 8051 compiler and also the list file. I program in embedded C.
