how to make copper pour in Eagle??
ex4
Full Member level 2
Full Member level 2
Jakarta, Indonesia
eagle copper pour
got confused in making copper pour in Eagle. need assistant on how 2 do it :|:|
eagle pour
How many layer pcb r u making?
The easiest copper pour upto 2 layer pcb i hv seen is in sprint layout.
It is like child's play.
copper pour eagle
i only make maximum of 2 layer, bottom and top. usully for home made pcb
but got confused on how 2 make copper pour??? use polygon or what???
eagle copper pouring
click "Polygon", type Gnd (or however your ground is named), choose an appropriate width > 0 (unless you want to bother your PCB manufacturer ) and draw the ground plane. You can see the plane after clicking "Ratsnest" - that's it
copper pour in eagle
wow, nice :D
btw, how to change the gap between the pour and the signal copper line?? or anybody complete eagle tutorial that cover this detail matter??
eagle pcb copper pour
This can be adjusted with the Isolate parameter. But you should consider the help on that matter as it additionally depends on the design rules (type: "help polygon")
copper pouring eagle
i usually use 2 layer pcb design, with the top layer is set as jumper layer. i can easily do it in orcad, how 2 set it up in eagle??
