how to make bipolar sine signal to unipolar sine signal
thelukuntla
Junior Member level 1
New delhi
i need feedback control of inverter with voltage as feedback. to fed the feedback signal to adc of microcontroller i need to make bipolar sine signal to unipolar one, i.e offsetting sine signal, a zero offset sine signal.
can anyone has idea or application notes related to. kindly post reply
thanks in advance
rakesh_trustworthy said:
i think you need a full wave bridge rectifier...........
Plz go through this...........
https://en.wikipedia.org/wiki/Diode_bridge
hi
what i need is level shifting of sine signal, i.e in general sine signal has ±Vm as positive and negative peaks respectively, but i need a sine signal with 2*Vm as positive peak and zero as negative peak, so entire sine signal should be level shifted, so that i can give it adc channel of microcontroller(microcontroller adc handles only positive signal in range of 0-5V.).
Just run it through an opamp and set it to add an DC offset voltage.
Make sure you dont have any caps in series or they will just block the DC offset.
Red
