How to make a solid state relay working at 48V DC & 220V
seyyah
Advanced Member level 2
solid state relay
How can we make a simple and reliable solid state relay which can work at 48VDC and 220VAC with a current rating of 1A
solid state relay
If you want to use DC voltage with TRIACs.
I suggest you to research for forced commutation.
This circuit allows you to turn off your TRIAC anytime.
Re: solid state relay
Try using optocoupler with the triac its easy. :eek:
No..isn´t that easy!!!
Problem with mixing DC and AC is that all (i know of) DC SSR are MOSFET absed and all AC are SCR based...
The only one manufacturer I am aware of is Teledyne:
https://www.teledynerelays.com/selectionmatrix.asp
Maybe you want to use a bridge-rectifier in series to the load and inside a normal high-volatge MOS/Bipolar transistor?
Hello
Go for MOC3062, it has built in zero-crossing, and can directly drive a triac.
Regards
