How to make a sine wave generator?
showntimoon
Junior Member level 3
i want to make a circuit that generates a sine wave with a specific freq.
how can it be done ??
Re: sine wave generator
You want to make a VCO? i.e. programmable output frequency?
Or you seek fixed frequency?
What about the linearity you seek?
Good Luck,
Ahmad,
yeah I seek fixed frequency
but I don't know wat u mean with linearity ??
Linearity can be expressed by the amplitude of fundamental freq. component (freq. you want) relative to adjacent second harmonic freq. component.
Linearity is the best if your oscillator has only single fundamental component..
You can make a simple sinusoidal oscillator using a 555 oscillator and simple LPF..
Depending on frequency.. This can give you relatively lwo freq. (up to few hundereds of KHz).
If you seek higher frequencies, you will go to XTAL or LC oscillators..
Hope that helps..
Ahmad,
    showntimoon
hi.to design a sinewave generator,the crystal oscillator would be the obvious choice.most of the applications use this.
sine wave generator
you can make it with a chain of inverters. it's very easy!
Hello
An simple circuit is the Wien Bridge
You can find in this forum
Regards
thank u all for help
plz could u give me the circuit using the 555
[/youtube][/GVideo]\][/quote]
I haven't the circuit but the idea is put a band-pass filter in the output of the 555 (pin 3) when this is in astable configuration
    showntimoon
If your frequency is as low as 90KHz, then you can go with one of 555 astable oscillators that're available free online, and choose your R's and C components values, untill you get the required freq. of oscillation..
Then Simply cascade a low pass filter with output of this oscillator (pin 3).. Make sure that cut-off of that filter is close to the required frequency..
You can download a free demo of similar calculator from the link below:
Best Wishes,
Ahmad,
