HAHUHOBRAD
Newbie level 1
I'm an avid tennis player and also do a little coaching. As in most sports, when someone is under pressure they tense up causing errors. In tennis, that tension is often in the grip of the raquet. I'd like to create a tennis trainer that could be installed on a raquet that would sense the pressure being applied on the grip and when gripped to tight, would make an audible beeping sound. I don't imagine this could be applied to an individuals raquet but rather to a training raquet that I could provide. The grip pressure sensors would need to be on at least 4 (4 sides) of the 8 bevelled sides of a tennis grip. The sensors would need to be very thin and run the length of the grip (handle). The grip would still need to be usable...meaning the sensors and tape used to apply them could not cover the whole grip making it slippery or unnatural to hold. The buzzer would need to be small enough to be mounted into the throat of the raquet. There is a small triangular area on most raquests that is about 2-3 inches on each side that a small buzzer device could fit in.
I've been searching for sensors but have found nothing that is simple enough for my brain to understand. I have no idea where to get a buzzer that is so small.
I hope this is enough information. I appreaciate any ideas you can share with me.
