How to make a power input protection ?
ahgu
Full Member level 3
Full Member level 3
Re: power input protection
I have power input that goes into the LDO.
I want to make sure the circuit does not go bad if somebody plug in 15 volts, or negative voltage?
What do I have put in the front of the circuit to make sure of that?
I thought about zener, But I guess I need a big zener. I don't want to put a fuse. it is too big.
thanks
ahgu
Added after 43 minutes:
Normal power input is 6.5VDC. I want make sure the circuit does not get blown when user put in like 24v and negatieve voltage.
Ususally, I will put a diode in series to the positive supply in order to prevent a reverse polarity.
In addition to the reverse polarity diode you can use a PolySwitch for over-current protection in combination with a transient voltage suppressor (instead of a zener diode) rated for 7.5V or higher..
You might try:
1) series self resetting fuse (Raychem Polyswitch)
2) shunted by a power zener
3) series schottky diode
Fuse (1) opens if Zener (2) voltage reached or reversed voltage. Schottky diode (3) protects LDO circuit from small reversed voltage (~ -1 volt) if negative voltage is applied.
Take a look at http://www.circuitprotection.com
can I use a polyswitch that is rate for 60V 0.2amp?
even though my voltage is arround 7v? but I don't want the current to go over 0.2 amp? I guess I don't undertand the voltage rating, does it matter? or just don't exceed that so it does not break the polyswitch?
