How to make a part of MMC card protected?
wendy
Newbie level 3
Newbie level 3
MMC card with security
hi, all:
I have a problem.
I have one MMC/SD card, I want to keep some contents on the MMC card to be write-protect, and not be copied illegally. The other capacity of MMC is used optionally.
Do you have any idea to give me some sense?
thanks.
wendy
Re: MMC card with security
Dude take a look at this
h**p://www.flashcards.co.nz/knowlege-base/mmc-card-vs-sd-card.html
SanDisks comes with right protections which you can use to protect ur data..
there are softwares which comes along with the media which helps to hide the filex which u want to.. unless or until u run that particular protection software which wud encrypt the data , u wudnt be able to use or make changes to these files.
with regards,
Thanks.
The link you give me cann ot be opened :(
I know there are some software to encrypt the files, can you recommend some good for me?it should be applied in flash memory.
Does MMC/SD card can be formatted to CDFS format?
