how to make a ding dong circuit ?
engraxate
Member level 3
Member level 3
ding dong circuit
how can I make a ding dong circuit ?
Any good idea are welcome
circuit ding-dong bell
You can make two narrow band filters at two frequencies. You pulse one and then the other. This simulates the response of striking a bell or other resonant physical object. To get the right overtone quality you may have to follow the filter with some nonlinear circuit. Or, have several pulsed filters each on an overtone of the lowest frequency one.
555 ding dong
I think the easiest way is to buy a IC for that. At Conrad you can buy this IC and oly need to plugin a speaker to it. This IC costs only 2€. I think this is the easiest way to create a ding-dong for doors.
Phytex
sab 0600 circuit
The IC type SAB 0600 for ding-deng-dong,0602 for ding-dong from S/i/e/m/e/n/s.It can direct driving a 8ohm speaker.
ding dong con 555
Here's a quickie that should take all of 5 minutes
to breadboard:
schematic din - don
And here is another circuit using the 555.
Nick C.
OH,it is so complicated way to use 555 timer!in china and taiwan or japan,many chips can do this easily,very cheap and sample.they are used as door bell,ding dong!
REGARDS!
