How to make 3 ports & radiation walls without overlaps(H
abdoeng
Advanced Member level 2
HFSS V8 help pls
hi all,i have problem in simulation of power divider ,how i make 3 ports and radiation walls without any overlaps between them
regards
HFSS V8 help pls
i think you should your problem with ensemble
in hfss 8.0,hope helps,its settings is easy
Re: HFSS V8 help pls
i know ,but i have no ensemble,how i do it HFSS
Overlaping isn't an issue. It won't change your solution. It's just there as a "warning!!"
i agree.it doesn't a matter,you can get the result.
