I have a problem, I need MUX that has 16inputs and 1output. In my local shop there is only 1of8 MUX, so how to make from two 1of8 one 1of16 MUX.
If it's not a problem, maybe I will need expend outputs also, so example of demux with 1input and 8outputs converted to demux with 1input to 16outputs would be super.
Thank you.
EDIT:
I corrected my mistake, it's 1of8 MUX, not 1of4 like I wrote it before.
At the moment I have only one ls151 so I can't try it.
I understand how this circuit works I just don't understand why didn't I get that idea (for example to look at the logic diagram of the MUX in the datasheet). :|
