wireless man
Full Member level 1
Hi, All,
May you tell me how to load the I/Q waveform file into ADS for simulation? Thanks a lot.
Maybe Matlab is a fitter tool for analyzing spectrum and CCDF. Anyway I tried to build a LoadIQ dsn for reference (It use "Readfile" component as it has no size limitation, you can copy it to your_project_path\networks\ and open it.).
Hello,
You should be able to do easily in AWR Visual System Simulator (VSS), where you can import IQ data in TXT format & add Spectrum & CCDF plots...There is an example ACPR_Test.emp ...This example demonstrates an ACPR, spectrum measurements for a CDMA IQ signal also you can add CCDF....
---manju---
