how to load fiels and kernal from boot loader
sagar474
Full Member level 5
Full Member level 5
India,kakinada
I have written the following code, this is my first boot sector program code.
and it works fine, but now how can i load other files and kernel. if I use CD/DVD.
BITS 16
jmp start			;jump to actual executing code
;------------------------------message set to display on the screen--------------
wellcome_msg db 'wellcome to Sagar cool new operating system',13,10,0,
reboot_msg db   'Your system is going to reboot now....',0,
reboot_key	db 'Press any key to reboot',13,10,0,
;------------------------------Main Boot loading process starts hear---------------
	start:
	mov ax, 07C0h		; Set data segment to where we're loaded
	mov ds, ax		;
	mov ax,9000h		;initialize the stack
	mov ss,ax		;
	mov sp,100h		;
	mov si,wellcome_msg	;source index register (SI) points to the wellcome_message offset
	call print		;call the print subroutine.
	mov si,reboot_key	; SI points to the off set of the string with label reboot_key
	call getkey
	mov si,reboot_msg	;SI points to offset of the string with label reboot_msg
	call reboot		;reboots the system.
	jmp $			; jump hear ie., infinite loop
;------------------------sub rotine---------------------------------------------
;----------------------to print string ------------------------------------------
	print:			;print subroutine
	mov ah,0eh;		;loads ah with 0eh function for print char in BIOS int 10h
	repet:			;
	lodsb			;al<-----[si] and si=si+1
	cmp al,0		;compare al and 0
	je done			;if al=0 then jump to lable don
	int 10h;		;call BIOS interrupt 10h video services
	jmp repet		;unconditional jump to label repit:
	done:
	ret			;return to main program.
;------------------------key board input------------------------------------------------
getkey:
mov ah,0			;function for keyboard char input stors ASCII value in al
int 16h				;BIOS keyboard interrupt
ret
;---------------------------reboot-----------------------------------------------------
     reboot:
                db 0EAh                 ; machine language to jump to FFFF:0000 (reboot)
                dw 0000h
                dw 0FFFFh
                ; no ret required; we're rebooting! (Hey, I just saved a byte :)
times 510-($-$$) db 0	; Pad remainder of boot sector with 0s
	dw 0xAA55		; The standard PC boot signature
please help
thank you
For CD/DVD it is totally different. First try to develop for Floppy boot sector and HDD boot sector.
For your reference see FreeDOS boot sector code.
When you completed the FDD/HDD boot sector then refer to syslinux package and Eltorito boot loader.
