BigBoss
Advanced Member level 7
Title is pretty clear.
I wish to load a bunch of default values for all my PCB designs as a standard in order to maintain the harmony/reconciliation between my designs
So, when you launch your PCB editor, default values ( layers,colors,constraints,routing options and other stuffs ) will already be loaded.
In fact, I created a parameters file but this one should be loaded manually and some tweaks are necessary instead of doing all those. I think one skill code can load all
those defaults into a new PCB design at once.
Is there any method ??
