How to learn embedded software?
epp
Full Member level 5
Full Member level 5
Does any tutorilal on learning embedded software programming exist?
How one can start to make some program? How one can decompose problem into small part and then connenct them into large program? Which tips and knacks exists for begginer in programming?
Thanks.
there are some great books about embedded programming.
if i start on a program.. first of all i build separate software blocks for controlling all the i/o
after that, if it works fine.. connect all the pieces together and start your main app.
    epp
Hi
The best way to learn is to read and practice a lot, this holds true for embedded systems as well. Start learning by writing simple programs e.g blinking an led etc.
Then start interfacing other modules with ucontroller e.g character lcds, graphic lcds,real time clocks,serial eeproms.
There is a lot of help available on all these devices and their intefacing.
Regards.
