How to know the mismatch of W and L of a transistor?
carpa
Member level 3
Member level 3
transistor mismatch avt
From the document of the foundry I can only know the mismatch of Vt, Vsat, Id. No figure points out the mismatch of the effectivive W and L. How can I know it?
mismatch,sigma,transistor -delta
use noise equation such as A/(w*L) to estimate offset vltage, whih A is dependent on your process.
Thank you for your reply. I am still confused with your noise equation. Can you give me a simple example?
You should have the parameters Avt (I forgot the exact name) in your datasheets to caluclate the % mismatches (in sigma) as sigma = Avt/sqrt(W*L). Try to seek it out.
If you draw transistor in different orientation, you will have mismatch w and W
sorry, terryssw said is right.
