How to know a mos capacitor's value?Thanks.
holddreams
Full Member level 6
Full Member level 6
Shanghai
mos cap
When the drain and source of a NMOS connected using as a capacitor(for example w/l=10u/1u),how to know the equivalent capacitor value?
Thanks.
capa mos value
1> the estimate value=W*L*(square capacitance), you can find the square capacitance (ff/um^2) in process file from process supplier.
2> also, you can simulate the MOSCAP and an idear cap in same condition by Hspice, compare their I/V curve, the same I/V curve means the same capacitor value.
    holddreams
how to know capacitor value
in hspice add a line
.options captab
then check the *.lis file , hspice will report capacitance of all nodes.
nmos capacitor
you can do dc simulation. The DC operation point will give the capacitor value
    holddreams
mos capacitor
You can do transient simulation,then calculate the capacitor value.
    holddreams
mos capacitor simulation
yep, perform a dc analysis in cadence and look at the op point of the transistor.
    holddreams
moscap capacitance
I think that you must do transient simulation If you want to know the MOS capacitor variation with Vgs variation.
    holddreams
hspice moscap
There are many methods.
I think calculating by hands is the best way.
    holddreams
hspice lx22 capacitance
Thanks a lot for your replies.
Would you please post the Hspice or spectre simulation file which include the dc and transient analysis here?
mos capacitor drain source
You can obtain the equivelent capacitance of MOSCAP by HSPICE transient simulation. caculate the total charge (Q) stored in the CAP in fixed voltage range (Vr), then the C=Q/Vr .
    holddreams
mos value
U can simply do an AC simulation with a voltage source connected in series with the mos cap, by setting the AC voltage to 1 and w=1 ,u can get the value of the capacitance as it is simply the current coming out of the ac source.
i=V/Zc
=jVwc ==> c=i/wV (for V=1, w=1) ==> c=i
    holddreams
hspice mosfet cagte capacatance
hi holddreams,
Using a ideal current charge the MOS cap,then using calculating function on cadence artist, you can get the C=I/(dv/dt).
pmos capacitor in cadence
I want to know how to show a "helped me " button?:D
nmos capacitance
The capacitor values depend on the voltage applied to the Gate of the transistor which decides its region.
Ex: Take Vgs is negative then it is in accumulation region and the capacitance is Cox now on if u increased Vgs and the depletion region is formed in that case the capacitance will be Cox+Cdepletion again u increased Vgs till the inversion takes place below the oxide and that time the capacitance becomes Cox. This are the three regions of operation called as
1.Accumulation,2. Weak Inversion,3.Strong Inversion and I think this might help u to get the capacitance of the NMOS. If anything else needed let me know.
capacitor using mos
Hi
you can plot the cap. by
.print lx18(m)
spice said:
LX18(m) = CGS+CGD+CGB
LX19(m) = LX32(m) = -CGD
LX20(m) = -CGS
LX21(m) = -CGB
LX22(m) = -CDB
LX23(m) = -CSB
LX33(m) = CGD+CDB+CDS
LX34(m) = -CDS
you can check it in the .lis file
.option captab
Stoned
mos capacitor ff/um
the easiest way is characterize yourself!
simulation of mos capacitor
Hi
Does Lx18(m) work in hspice?
mos capacitance simulator
There is a demo directory that comes with HSPICE, which contains examples using LX18 to charactrize MOS caps.
