how to judge positive feedback or negative feedback for amp
ithink
Junior Member level 2
i wanna design a comparator with positive feedback, but i have no clear concept about positive feedback in OP amp, you may give me some good ideas?thank you
Re: how to judge positive feedback or negative feedback for
in common sense,if you want to design a high speed comparator,one or two stages of preamplification followed by a track-and-latch stage is the most familiar architecure.the preamplification is always a simple OTA.the track-and-latch stage can give a high speed with moderate gain.so i can't understand your problem,if you want to use the AMP as the comparator,then speed always be slow if you want to get a high resolution.so what the meaning of "a comparator with positive feedback"? ps:ken matin's book(analog circuit design),chapter 7 will gives you some help.
You can inject one signal in the feedback loop (break point) ,If the output signal phase is the same as input , this system is in positive feedback.
