how to interface with memory interface generator (mig7) in vivado?
hamidkavianathar
Member level 5
Hi guys
I want to read data from a sdram memory. I'm using vivado and kintex7. I changed the xdc file according my board. but I received this errors:
[Place 30-370] An unconstrained Phaser instance has been found. Phaser instances and their associated IO logic must be LOC constrained to a legal site locations for placement to succeed. Check to see whether all core constraints were properly used or manually add LOC constraints for the following instance(s).
Unconstrained Phaser instance(s):
Inst 'phaser_in_gen.phaser_in'
[Place 30-99] Placer failed with error: 'Implementation Feasibility check failed, Please see the previously displayed individual error or warning messages for more details.'
Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
[Common 17-69] Command failed: Placer could not place all instances
and this is my xdc file:
##  Xilinx, Inc. 2010            www.xilinx.com
##  Sun Jul 3 11:26:33 2016
##  Generated by MIG Version 2.4
##  File name :       design_1_mig_7series_0_2.xdc
##  Details :     Constraints file
##                    FPGA Family:       KINTEX7
##                    FPGA Part:         XC7K160T-FFG676
##                    Speedgrade:        -2
##                    Design Entry:      VERILOG
##                    Frequency:         0 MHz
##                    Time Period:       2500 ps
## Controller 0
## Memory Device: DDR3_SDRAM->SODIMMs->hamidddd
## Data Width: 64
## Data Mask: 1
create_clock -period 1.25 [get_ports sys_clk_i]
create_clock -period 5 [get_ports clk_ref_i]
############## NET - IOSTANDARD ##################
# PadFunction: IO_L1N_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[0]}]
set_property SLEW FAST [get_ports {ddr3_dq[0]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[0]}]
set_property PACKAGE_PIN U6 [get_ports {ddr3_dq[0]}]
# PadFunction: IO_L2P_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[1]}]
set_property SLEW FAST [get_ports {ddr3_dq[1]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[1]}]
set_property PACKAGE_PIN V6 [get_ports {ddr3_dq[1]}]
# PadFunction: IO_L2N_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[2]}]
set_property SLEW FAST [get_ports {ddr3_dq[2]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[2]}]
set_property PACKAGE_PIN U2 [get_ports {ddr3_dq[2]}]
# PadFunction: IO_L4P_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[3]}]
set_property SLEW FAST [get_ports {ddr3_dq[3]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[3]}]
set_property PACKAGE_PIN V3 [get_ports {ddr3_dq[3]}]
# PadFunction: IO_L4N_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[4]}]
set_property SLEW FAST [get_ports {ddr3_dq[4]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[4]}]
set_property PACKAGE_PIN U7 [get_ports {ddr3_dq[4]}]
# PadFunction: IO_L5P_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[5]}]
set_property SLEW FAST [get_ports {ddr3_dq[5]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[5]}]
set_property PACKAGE_PIN U5 [get_ports {ddr3_dq[5]}]
# PadFunction: IO_L5N_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[6]}]
set_property SLEW FAST [get_ports {ddr3_dq[6]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[6]}]
set_property PACKAGE_PIN W3 [get_ports {ddr3_dq[6]}]
# PadFunction: IO_L6P_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[7]}]
set_property SLEW FAST [get_ports {ddr3_dq[7]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[7]}]
set_property PACKAGE_PIN V4 [get_ports {ddr3_dq[7]}]
# PadFunction: IO_L7N_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[8]}]
set_property SLEW FAST [get_ports {ddr3_dq[8]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[8]}]
set_property PACKAGE_PIN V1 [get_ports {ddr3_dq[8]}]
# PadFunction: IO_L8P_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[9]}]
set_property SLEW FAST [get_ports {ddr3_dq[9]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[9]}]
set_property PACKAGE_PIN Y3 [get_ports {ddr3_dq[9]}]
# PadFunction: IO_L8N_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[10]}]
set_property SLEW FAST [get_ports {ddr3_dq[10]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[10]}]
set_property PACKAGE_PIN Y1 [get_ports {ddr3_dq[10]}]
# PadFunction: IO_L10P_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[11]}]
set_property SLEW FAST [get_ports {ddr3_dq[11]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[11]}]
set_property PACKAGE_PIN AA3 [get_ports {ddr3_dq[11]}]
# PadFunction: IO_L10N_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[12]}]
set_property SLEW FAST [get_ports {ddr3_dq[12]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[12]}]
set_property PACKAGE_PIN Y2 [get_ports {ddr3_dq[12]}]
# PadFunction: IO_L11P_T1_SRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[13]}]
set_property SLEW FAST [get_ports {ddr3_dq[13]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[13]}]
set_property PACKAGE_PIN W1 [get_ports {ddr3_dq[13]}]
# PadFunction: IO_L11N_T1_SRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[14]}]
set_property SLEW FAST [get_ports {ddr3_dq[14]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[14]}]
set_property PACKAGE_PIN AC2 [get_ports {ddr3_dq[14]}]
# PadFunction: IO_L12P_T1_MRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[15]}]
set_property SLEW FAST [get_ports {ddr3_dq[15]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[15]}]
set_property PACKAGE_PIN AA2 [get_ports {ddr3_dq[15]}]
# PadFunction: IO_L13P_T2_MRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[16]}]
set_property SLEW FAST [get_ports {ddr3_dq[16]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[16]}]
set_property PACKAGE_PIN AC3 [get_ports {ddr3_dq[16]}]
# PadFunction: IO_L13N_T2_MRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[17]}]
set_property SLEW FAST [get_ports {ddr3_dq[17]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[17]}]
set_property PACKAGE_PIN AB4 [get_ports {ddr3_dq[17]}]
# PadFunction: IO_L14P_T2_SRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[18]}]
set_property SLEW FAST [get_ports {ddr3_dq[18]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[18]}]
set_property PACKAGE_PIN Y5 [get_ports {ddr3_dq[18]}]
# PadFunction: IO_L14N_T2_SRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[19]}]
set_property SLEW FAST [get_ports {ddr3_dq[19]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[19]}]
set_property PACKAGE_PIN Y6 [get_ports {ddr3_dq[19]}]
# PadFunction: IO_L16N_T2_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[20]}]
set_property SLEW FAST [get_ports {ddr3_dq[20]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[20]}]
set_property PACKAGE_PIN AC4 [get_ports {ddr3_dq[20]}]
# PadFunction: IO_L17P_T2_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[21]}]
set_property SLEW FAST [get_ports {ddr3_dq[21]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[21]}]
set_property PACKAGE_PIN AA4 [get_ports {ddr3_dq[21]}]
# PadFunction: IO_L17N_T2_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[22]}]
set_property SLEW FAST [get_ports {ddr3_dq[22]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[22]}]
set_property PACKAGE_PIN AC6 [get_ports {ddr3_dq[22]}]
# PadFunction: IO_L18P_T2_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[23]}]
set_property SLEW FAST [get_ports {ddr3_dq[23]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[23]}]
set_property PACKAGE_PIN AB6 [get_ports {ddr3_dq[23]}]
# PadFunction: IO_L20P_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[24]}]
set_property SLEW FAST [get_ports {ddr3_dq[24]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[24]}]
set_property PACKAGE_PIN AD1 [get_ports {ddr3_dq[24]}]
# PadFunction: IO_L20N_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[25]}]
set_property SLEW FAST [get_ports {ddr3_dq[25]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[25]}]
set_property PACKAGE_PIN AD4 [get_ports {ddr3_dq[25]}]
# PadFunction: IO_L22P_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[26]}]
set_property SLEW FAST [get_ports {ddr3_dq[26]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[26]}]
set_property PACKAGE_PIN AF2 [get_ports {ddr3_dq[26]}]
# PadFunction: IO_L22N_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[27]}]
set_property SLEW FAST [get_ports {ddr3_dq[27]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[27]}]
set_property PACKAGE_PIN AE3 [get_ports {ddr3_dq[27]}]
# PadFunction: IO_L23P_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[28]}]
set_property SLEW FAST [get_ports {ddr3_dq[28]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[28]}]
set_property PACKAGE_PIN AE2 [get_ports {ddr3_dq[28]}]
# PadFunction: IO_L23N_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[29]}]
set_property SLEW FAST [get_ports {ddr3_dq[29]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[29]}]
set_property PACKAGE_PIN AF3 [get_ports {ddr3_dq[29]}]
# PadFunction: IO_L24P_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[30]}]
set_property SLEW FAST [get_ports {ddr3_dq[30]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[30]}]
set_property PACKAGE_PIN AE5 [get_ports {ddr3_dq[30]}]
# PadFunction: IO_L24N_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[31]}]
set_property SLEW FAST [get_ports {ddr3_dq[31]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[31]}]
set_property PACKAGE_PIN AE6 [get_ports {ddr3_dq[31]}]
# PadFunction: IO_L1N_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[32]}]
set_property SLEW FAST [get_ports {ddr3_dq[32]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[32]}]
set_property PACKAGE_PIN AF15 [get_ports {ddr3_dq[32]}]
# PadFunction: IO_L2P_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[33]}]
set_property SLEW FAST [get_ports {ddr3_dq[33]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[33]}]
set_property PACKAGE_PIN AD15 [get_ports {ddr3_dq[33]}]
# PadFunction: IO_L2N_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[34]}]
set_property SLEW FAST [get_ports {ddr3_dq[34]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[34]}]
set_property PACKAGE_PIN AE17 [get_ports {ddr3_dq[34]}]
# PadFunction: IO_L4P_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[35]}]
set_property SLEW FAST [get_ports {ddr3_dq[35]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[35]}]
set_property PACKAGE_PIN AD16 [get_ports {ddr3_dq[35]}]
# PadFunction: IO_L4N_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[36]}]
set_property SLEW FAST [get_ports {ddr3_dq[36]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[36]}]
set_property PACKAGE_PIN AE15 [get_ports {ddr3_dq[36]}]
# PadFunction: IO_L5P_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[37]}]
set_property SLEW FAST [get_ports {ddr3_dq[37]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[37]}]
set_property PACKAGE_PIN AF14 [get_ports {ddr3_dq[37]}]
# PadFunction: IO_L5N_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[38]}]
set_property SLEW FAST [get_ports {ddr3_dq[38]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[38]}]
set_property PACKAGE_PIN AF19 [get_ports {ddr3_dq[38]}]
# PadFunction: IO_L6P_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[39]}]
set_property SLEW FAST [get_ports {ddr3_dq[39]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[39]}]
set_property PACKAGE_PIN AF20 [get_ports {ddr3_dq[39]}]
# PadFunction: IO_L7N_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[40]}]
set_property SLEW FAST [get_ports {ddr3_dq[40]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[40]}]
set_property PACKAGE_PIN AC14 [get_ports {ddr3_dq[40]}]
# PadFunction: IO_L8P_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[41]}]
set_property SLEW FAST [get_ports {ddr3_dq[41]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[41]}]
set_property PACKAGE_PIN AB15 [get_ports {ddr3_dq[41]}]
# PadFunction: IO_L8N_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[42]}]
set_property SLEW FAST [get_ports {ddr3_dq[42]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[42]}]
set_property PACKAGE_PIN AC16 [get_ports {ddr3_dq[42]}]
# PadFunction: IO_L10P_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[43]}]
set_property SLEW FAST [get_ports {ddr3_dq[43]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[43]}]
set_property PACKAGE_PIN AB16 [get_ports {ddr3_dq[43]}]
# PadFunction: IO_L10N_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[44]}]
set_property SLEW FAST [get_ports {ddr3_dq[44]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[44]}]
set_property PACKAGE_PIN AD14 [get_ports {ddr3_dq[44]}]
# PadFunction: IO_L11P_T1_SRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[45]}]
set_property SLEW FAST [get_ports {ddr3_dq[45]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[45]}]
set_property PACKAGE_PIN AB14 [get_ports {ddr3_dq[45]}]
# PadFunction: IO_L11N_T1_SRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[46]}]
set_property SLEW FAST [get_ports {ddr3_dq[46]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[46]}]
set_property PACKAGE_PIN AA17 [get_ports {ddr3_dq[46]}]
# PadFunction: IO_L12P_T1_MRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[47]}]
set_property SLEW FAST [get_ports {ddr3_dq[47]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[47]}]
set_property PACKAGE_PIN AA18 [get_ports {ddr3_dq[47]}]
# PadFunction: IO_L13P_T2_MRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[48]}]
set_property SLEW FAST [get_ports {ddr3_dq[48]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[48]}]
set_property PACKAGE_PIN AC17 [get_ports {ddr3_dq[48]}]
# PadFunction: IO_L13N_T2_MRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[49]}]
set_property SLEW FAST [get_ports {ddr3_dq[49]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[49]}]
set_property PACKAGE_PIN AC18 [get_ports {ddr3_dq[49]}]
# PadFunction: IO_L14P_T2_SRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[50]}]
set_property SLEW FAST [get_ports {ddr3_dq[50]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[50]}]
set_property PACKAGE_PIN AA20 [get_ports {ddr3_dq[50]}]
# PadFunction: IO_L14N_T2_SRCC_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[51]}]
set_property SLEW FAST [get_ports {ddr3_dq[51]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[51]}]
set_property PACKAGE_PIN AA19 [get_ports {ddr3_dq[51]}]
# PadFunction: IO_L16N_T2_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[52]}]
set_property SLEW FAST [get_ports {ddr3_dq[52]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[52]}]
set_property PACKAGE_PIN AD19 [get_ports {ddr3_dq[52]}]
# PadFunction: IO_L17P_T2_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[53]}]
set_property SLEW FAST [get_ports {ddr3_dq[53]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[53]}]
set_property PACKAGE_PIN AC19 [get_ports {ddr3_dq[53]}]
# PadFunction: IO_L17N_T2_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[54]}]
set_property SLEW FAST [get_ports {ddr3_dq[54]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[54]}]
set_property PACKAGE_PIN AB17 [get_ports {ddr3_dq[54]}]
# PadFunction: IO_L18P_T2_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[55]}]
set_property SLEW FAST [get_ports {ddr3_dq[55]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[55]}]
set_property PACKAGE_PIN AB19 [get_ports {ddr3_dq[55]}]
# PadFunction: IO_L20P_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[56]}]
set_property SLEW FAST [get_ports {ddr3_dq[56]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[56]}]
set_property PACKAGE_PIN W15 [get_ports {ddr3_dq[56]}]
# PadFunction: IO_L20N_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[57]}]
set_property SLEW FAST [get_ports {ddr3_dq[57]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[57]}]
set_property PACKAGE_PIN W16 [get_ports {ddr3_dq[57]}]
# PadFunction: IO_L22P_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[58]}]
set_property SLEW FAST [get_ports {ddr3_dq[58]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[58]}]
set_property PACKAGE_PIN V16 [get_ports {ddr3_dq[58]}]
# PadFunction: IO_L22N_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[59]}]
set_property SLEW FAST [get_ports {ddr3_dq[59]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[59]}]
set_property PACKAGE_PIN V18 [get_ports {ddr3_dq[59]}]
# PadFunction: IO_L23P_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[60]}]
set_property SLEW FAST [get_ports {ddr3_dq[60]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[60]}]
set_property PACKAGE_PIN W14 [get_ports {ddr3_dq[60]}]
# PadFunction: IO_L23N_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[61]}]
set_property SLEW FAST [get_ports {ddr3_dq[61]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[61]}]
set_property PACKAGE_PIN Y17 [get_ports {ddr3_dq[61]}]
# PadFunction: IO_L24P_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[62]}]
set_property SLEW FAST [get_ports {ddr3_dq[62]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[62]}]
set_property PACKAGE_PIN V14 [get_ports {ddr3_dq[62]}]
# PadFunction: IO_L24N_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dq[63]}]
set_property SLEW FAST [get_ports {ddr3_dq[63]}]
set_property IOSTANDARD SSTL15_T_DCI [get_ports {ddr3_dq[63]}]
set_property PACKAGE_PIN V19 [get_ports {ddr3_dq[63]}]
# PadFunction: IO_L1P_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[13]}]
set_property SLEW FAST [get_ports {ddr3_addr[13]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[13]}]
set_property PACKAGE_PIN AA7 [get_ports {ddr3_addr[13]}]
# PadFunction: IO_L1N_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[12]}]
set_property SLEW FAST [get_ports {ddr3_addr[12]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[12]}]
set_property PACKAGE_PIN AC8 [get_ports {ddr3_addr[12]}]
# PadFunction: IO_L2P_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[11]}]
set_property SLEW FAST [get_ports {ddr3_addr[11]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[11]}]
set_property PACKAGE_PIN AA12 [get_ports {ddr3_addr[11]}]
# PadFunction: IO_L2N_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[10]}]
set_property SLEW FAST [get_ports {ddr3_addr[10]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[10]}]
set_property PACKAGE_PIN Y8 [get_ports {ddr3_addr[10]}]
# PadFunction: IO_L4P_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[9]}]
set_property SLEW FAST [get_ports {ddr3_addr[9]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[9]}]
set_property PACKAGE_PIN AB7 [get_ports {ddr3_addr[9]}]
# PadFunction: IO_L4N_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[8]}]
set_property SLEW FAST [get_ports {ddr3_addr[8]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[8]}]
set_property PACKAGE_PIN Y11 [get_ports {ddr3_addr[8]}]
# PadFunction: IO_L5P_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[7]}]
set_property SLEW FAST [get_ports {ddr3_addr[7]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[7]}]
set_property PACKAGE_PIN Y7 [get_ports {ddr3_addr[7]}]
# PadFunction: IO_L5N_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[6]}]
set_property SLEW FAST [get_ports {ddr3_addr[6]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[6]}]
set_property PACKAGE_PIN AA9 [get_ports {ddr3_addr[6]}]
# PadFunction: IO_L6P_T0_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[5]}]
set_property SLEW FAST [get_ports {ddr3_addr[5]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[5]}]
set_property PACKAGE_PIN AC7 [get_ports {ddr3_addr[5]}]
# PadFunction: IO_L7P_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[4]}]
set_property SLEW FAST [get_ports {ddr3_addr[4]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[4]}]
set_property PACKAGE_PIN AE7 [get_ports {ddr3_addr[4]}]
# PadFunction: IO_L7N_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[3]}]
set_property SLEW FAST [get_ports {ddr3_addr[3]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[3]}]
set_property PACKAGE_PIN AB9 [get_ports {ddr3_addr[3]}]
# PadFunction: IO_L8P_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[2]}]
set_property SLEW FAST [get_ports {ddr3_addr[2]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[2]}]
set_property PACKAGE_PIN AF7 [get_ports {ddr3_addr[2]}]
# PadFunction: IO_L8N_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[1]}]
set_property SLEW FAST [get_ports {ddr3_addr[1]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[1]}]
set_property PACKAGE_PIN W9 [get_ports {ddr3_addr[1]}]
# PadFunction: IO_L9P_T1_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_addr[0]}]
set_property SLEW FAST [get_ports {ddr3_addr[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_addr[0]}]
set_property PACKAGE_PIN V9 [get_ports {ddr3_addr[0]}]
# PadFunction: IO_L9N_T1_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ba[2]}]
set_property SLEW FAST [get_ports {ddr3_ba[2]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_ba[2]}]
set_property PACKAGE_PIN V7 [get_ports {ddr3_ba[2]}]
# PadFunction: IO_L10P_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ba[1]}]
set_property SLEW FAST [get_ports {ddr3_ba[1]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_ba[1]}]
set_property PACKAGE_PIN W11 [get_ports {ddr3_ba[1]}]
# PadFunction: IO_L10N_T1_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ba[0]}]
set_property SLEW FAST [get_ports {ddr3_ba[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_ba[0]}]
set_property PACKAGE_PIN AE12 [get_ports {ddr3_ba[0]}]
# PadFunction: IO_L11P_T1_SRCC_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ras_n}]
set_property SLEW FAST [get_ports {ddr3_ras_n}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_ras_n}]
set_property PACKAGE_PIN AE13 [get_ports {ddr3_ras_n}]
# PadFunction: IO_L11N_T1_SRCC_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_cas_n}]
set_property SLEW FAST [get_ports {ddr3_cas_n}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_cas_n}]
set_property PACKAGE_PIN AC13 [get_ports {ddr3_cas_n}]
# PadFunction: IO_L12P_T1_MRCC_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_we_n}]
set_property SLEW FAST [get_ports {ddr3_we_n}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_we_n}]
set_property PACKAGE_PIN AD13 [get_ports {ddr3_we_n}]
# PadFunction: IO_L12N_T1_MRCC_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_reset_n}]
set_property SLEW FAST [get_ports {ddr3_reset_n}]
set_property IOSTANDARD LVCMOS15 [get_ports {ddr3_reset_n}]
set_property PACKAGE_PIN AF8 [get_ports {ddr3_reset_n}]
# PadFunction: IO_L15P_T2_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_cke[0]}]
set_property SLEW FAST [get_ports {ddr3_cke[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_cke[0]}]
set_property PACKAGE_PIN AA8 [get_ports {ddr3_cke[0]}]
# PadFunction: IO_L15N_T2_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_odt[0]}]
set_property SLEW FAST [get_ports {ddr3_odt[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_odt[0]}]
set_property PACKAGE_PIN Y13 [get_ports {ddr3_odt[0]}]
# PadFunction: IO_L12N_T1_MRCC_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_cs_n[0]}]
set_property SLEW FAST [get_ports {ddr3_cs_n[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_cs_n[0]}]
set_property PACKAGE_PIN AC12 [get_ports {ddr3_cs_n[0]}]
# PadFunction: IO_L1P_T0_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[0]}]
set_property SLEW FAST [get_ports {ddr3_dm[0]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[0]}]
set_property PACKAGE_PIN U1 [get_ports {ddr3_dm[0]}]
# PadFunction: IO_L7P_T1_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[1]}]
set_property SLEW FAST [get_ports {ddr3_dm[1]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[1]}]
set_property PACKAGE_PIN AB2 [get_ports {ddr3_dm[1]}]
# PadFunction: IO_L16P_T2_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[2]}]
set_property SLEW FAST [get_ports {ddr3_dm[2]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[2]}]
set_property PACKAGE_PIN AD6 [get_ports {ddr3_dm[2]}]
# PadFunction: IO_L19P_T3_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[3]}]
set_property SLEW FAST [get_ports {ddr3_dm[3]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[3]}]
set_property PACKAGE_PIN AE1 [get_ports {ddr3_dm[3]}]
# PadFunction: IO_L1P_T0_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[4]}]
set_property SLEW FAST [get_ports {ddr3_dm[4]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[4]}]
set_property PACKAGE_PIN AF17 [get_ports {ddr3_dm[4]}]
# PadFunction: IO_L7P_T1_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[5]}]
set_property SLEW FAST [get_ports {ddr3_dm[5]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[5]}]
set_property PACKAGE_PIN AA15 [get_ports {ddr3_dm[5]}]
# PadFunction: IO_L16P_T2_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[6]}]
set_property SLEW FAST [get_ports {ddr3_dm[6]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[6]}]
set_property PACKAGE_PIN AB20 [get_ports {ddr3_dm[6]}]
# PadFunction: IO_L19P_T3_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dm[7]}]
set_property SLEW FAST [get_ports {ddr3_dm[7]}]
set_property IOSTANDARD SSTL15 [get_ports {ddr3_dm[7]}]
set_property PACKAGE_PIN V17 [get_ports {ddr3_dm[7]}]
# PadFunction: IO_L14P_T2_SRCC_33
#set_property VCCAUX_IO DONTCARE [get_ports {sys_clk_i}]
#set_property IOSTANDARD SSTL15 [get_ports {sys_clk_i}]
#set_property PACKAGE_PIN AA10 [get_ports {sys_clk_i}]
# PadFunction: IO_L11P_T1_SRCC_12
#set_property IOSTANDARD LVCMOS25 [get_ports {clk_ref_i}]
#set_property PACKAGE_PIN AA23 [get_ports {clk_ref_i}]
# PadFunction: IO_L3P_T0_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[0]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[0]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[0]}]
set_property PACKAGE_PIN W6 [get_ports {ddr3_dqs_p[0]}]
# PadFunction: IO_L3N_T0_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[0]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[0]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[0]}]
set_property PACKAGE_PIN W5 [get_ports {ddr3_dqs_n[0]}]
# PadFunction: IO_L9P_T1_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[1]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[1]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[1]}]
set_property PACKAGE_PIN AB1 [get_ports {ddr3_dqs_p[1]}]
# PadFunction: IO_L9N_T1_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[1]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[1]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[1]}]
set_property PACKAGE_PIN AC1 [get_ports {ddr3_dqs_n[1]}]
# PadFunction: IO_L15P_T2_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[2]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[2]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[2]}]
set_property PACKAGE_PIN AA5 [get_ports {ddr3_dqs_p[2]}]
# PadFunction: IO_L15N_T2_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[2]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[2]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[2]}]
set_property PACKAGE_PIN AB5 [get_ports {ddr3_dqs_n[2]}]
# PadFunction: IO_L21P_T3_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[3]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[3]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[3]}]
set_property PACKAGE_PIN AF5 [get_ports {ddr3_dqs_p[3]}]
# PadFunction: IO_L21N_T3_DQS_34
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[3]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[3]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[3]}]
set_property PACKAGE_PIN AF4 [get_ports {ddr3_dqs_n[3]}]
# PadFunction: IO_L3P_T0_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[4]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[4]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[4]}]
set_property PACKAGE_PIN AE18 [get_ports {ddr3_dqs_p[4]}]
# PadFunction: IO_L3N_T0_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[4]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[4]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[4]}]
set_property PACKAGE_PIN AF18 [get_ports {ddr3_dqs_n[4]}]
# PadFunction: IO_L9P_T1_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[5]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[5]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[5]}]
set_property PACKAGE_PIN Y15 [get_ports {ddr3_dqs_p[5]}]
# PadFunction: IO_L9N_T1_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[5]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[5]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[5]}]
set_property PACKAGE_PIN Y16 [get_ports {ddr3_dqs_n[5]}]
# PadFunction: IO_L15P_T2_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[6]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[6]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[6]}]
set_property PACKAGE_PIN AD20 [get_ports {ddr3_dqs_p[6]}]
# PadFunction: IO_L15N_T2_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[6]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[6]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[6]}]
set_property PACKAGE_PIN AE20 [get_ports {ddr3_dqs_n[6]}]
# PadFunction: IO_L21P_T3_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_p[7]}]
set_property SLEW FAST [get_ports {ddr3_dqs_p[7]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_p[7]}]
set_property PACKAGE_PIN W18 [get_ports {ddr3_dqs_p[7]}]
# PadFunction: IO_L21N_T3_DQS_32
set_property VCCAUX_IO NORMAL [get_ports {ddr3_dqs_n[7]}]
set_property SLEW FAST [get_ports {ddr3_dqs_n[7]}]
set_property IOSTANDARD DIFF_SSTL15_T_DCI [get_ports {ddr3_dqs_n[7]}]
set_property PACKAGE_PIN W19 [get_ports {ddr3_dqs_n[7]}]
# PadFunction: IO_L3P_T0_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ck_p[0]}]
set_property SLEW FAST [get_ports {ddr3_ck_p[0]}]
set_property IOSTANDARD DIFF_SSTL15 [get_ports {ddr3_ck_p[0]}]
set_property PACKAGE_PIN AC9 [get_ports {ddr3_ck_p[0]}]
# PadFunction: IO_L3N_T0_DQS_33
set_property VCCAUX_IO NORMAL [get_ports {ddr3_ck_n[0]}]
set_property SLEW FAST [get_ports {ddr3_ck_n[0]}]
set_property IOSTANDARD DIFF_SSTL15 [get_ports {ddr3_ck_n[0]}]
set_property PACKAGE_PIN AD9 [get_ports {ddr3_ck_n[0]}]
#set_property LOC PHASER_OUT_PHY_X1Y3 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y7 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y6 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y5 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y11 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y10 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y9 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_out}]
#set_property LOC PHASER_OUT_PHY_X1Y8 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/phaser_out}]
#set_property LOC PHASER_IN_PHY_X1Y3 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/phaser_in_gen.phaser_in}]
## set_property LOC PHASER_IN_PHY_X1Y7 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_in_gen.phaser_in}]
## set_property LOC PHASER_IN_PHY_X1Y6 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_in_gen.phaser_in}]
## set_property LOC PHASER_IN_PHY_X1Y5 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y11 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y10 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y9 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/phaser_in_gen.phaser_in}]
#set_property LOC PHASER_IN_PHY_X1Y8 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/phaser_in_gen.phaser_in}]
#set_property LOC OUT_FIFO_X1Y3 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/out_fifo}]
#set_property LOC OUT_FIFO_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/out_fifo}]
#set_property LOC OUT_FIFO_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/out_fifo}]
#set_property LOC OUT_FIFO_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/out_fifo}]
#set_property LOC OUT_FIFO_X1Y7 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/out_fifo}]
#set_property LOC OUT_FIFO_X1Y6 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/out_fifo}]
#set_property LOC OUT_FIFO_X1Y5 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/out_fifo}]
#set_property LOC OUT_FIFO_X1Y11 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/out_fifo}]
#set_property LOC OUT_FIFO_X1Y10 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/out_fifo}]
#set_property LOC OUT_FIFO_X1Y9 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/out_fifo}]
#set_property LOC OUT_FIFO_X1Y8 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/out_fifo}]
#set_property LOC IN_FIFO_X1Y3 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y11 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y10 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y9 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/in_fifo_gen.in_fifo}]
#set_property LOC IN_FIFO_X1Y8 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/in_fifo_gen.in_fifo}]
#set_property LOC PHY_CONTROL_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/phy_control_i}]
#set_property LOC PHY_CONTROL_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/phy_control_i}]
#set_property LOC PHY_CONTROL_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/phy_control_i}]
#set_property LOC PHASER_REF_X1Y0 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/phaser_ref_i}]
#set_property LOC PHASER_REF_X1Y1 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_1.u_ddr_phy_4lanes/phaser_ref_i}]
#set_property LOC PHASER_REF_X1Y2 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/phaser_ref_i}]
#set_property LOC OLOGIC_X1Y43 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y31 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y19 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y7 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_2.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y143 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y131 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y119 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/ddr_byte_group_io/*slave_ts}]
#set_property LOC OLOGIC_X1Y107 [get_cells  -hier -filter {NAME =~ */ddr_phy_4lanes_0.u_ddr_phy_4lanes/ddr_byte_lane_A.ddr_byte_lane_A/ddr_byte_group_io/*slave_ts}]
#set_property LOC PLLE2_ADV_X1Y1 [get_cells -hier -filter {NAME =~ */u_ddr3_infrastructure/plle2_i}]
#set_property LOC MMCME2_ADV_X1Y1 [get_cells -hier -filter {NAME =~ */u_ddr3_infrastructure/gen_mmcm.mmcm_i}]
#set_multicycle_path -from [get_cells -hier -filter {NAME =~ */mc0/mc_read_idle_r_reg}] \
#                    -to   [get_cells -hier -filter {NAME =~ */input_[?].iserdes_dq_.iserdesdq}] \
#                    -setup 6
#                    -hold 5
#set_false_path -through [get_pins -filter {NAME =~ */DQSFOUND} -of [get_cells -hier -filter {REF_NAME == PHASER_IN_PHY}]]
#set_multicycle_path -through [get_pins -filter {NAME =~ */OSERDESRST} -of [get_cells -hier -filter {REF_NAME == PHASER_OUT_PHY}]] -setup 2 -start
#set_multicycle_path -through [get_pins -filter {NAME =~ */OSERDESRST} -of [get_cells -hier -filter {REF_NAME == PHASER_OUT_PHY}]] -hold 1 -start
#set_max_delay -datapath_only -from [get_cells -hier -filter {NAME =~ *temp_mon_enabled.u_tempmon/* && IS_SEQUENTIAL}] -to [get_cells -hier -filter {NAME =~ *temp_mon_enabled.u_tempmon/device_temp_sync_r1*}] 20
#set_max_delay -from [get_cells -hier *rstdiv0_sync_r1_reg*] -to [get_pins -filter {NAME =~ */RESET} -of [get_cells -hier -filter {REF_NAME == PHY_CONTROL}]] -datapath_only 5
#set_false_path -through [get_pins -hier -filter {NAME =~ */u_iodelay_ctrl/sys_rst}]
#set_max_delay -datapath_only -from [get_cells -hier -filter {NAME =~ *ddr3_infrastructure/rstdiv0_sync_r1_reg*}] -to [get_cells -hier -filter {NAME =~ *temp_mon_enabled.u_tempmon/xadc_supplied_temperature.rst_r1*}] 20
what should I do?
thanks.
There's a similar problem listed on Xilinx's Answer Record:
http://www.xilinx.com/support/answers/46617.html
thanks for the comment.
I changed my xdc file and now I received this errors:
[DRC 23-20] Rule violation (RTSTAT-2) Partially routed net - 6 net(s) are partially routed. The problem bus(es) and/or net(s) are design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/oserdes_clk, design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/oserdes_clk, design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/oserdes_clk, design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_B.ddr_byte_lane_B/oserdes_clkdiv, design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_C.ddr_byte_lane_C/oserdes_clkdiv, design_1_i/mig_7series_0/u_design_1_mig_7series_0_2_mig/u_memc_ui_top_axi/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/u_ddr_mc_phy/ddr_phy_4lanes_1.u_ddr_phy_4lanes/ddr_byte_lane_D.ddr_byte_lane_D/oserdes_clkdiv.
It is difficult to diagnose problems such as these with just screenshot infos.
Let me ask you something, did you use the Xilinx connection automation while building your project?
If yes, are you sure that DRC at that time had no errors?
yes. the problem began when I changed the xdc file. could you tell me, how can I do it properly?
At the board level the DDR i/f signals would remain very similar.
What mostly varies are the clock and reset inputs along with may be some control i/p or o/p.
THe SS says that ddr_phy signals are unrouted/partially-routed. Recheck their connection in the XDC file.
Take the help of the Xilinx eg_design and see how the connections are done there!
thank you for the comment.
yes, I used the Xilinx connection automation while building my project. there wasn't any problem when I created it, but when I changed the .xdc file, everything destroyed.
Well then my opinion would be to start investigating all the ports of the top-level design. Make sure you have put proper constraints to all the required top-level ports.
Begin with by comparing your top-level ports, the Xilinx XDC and your XDC. Find out what has changed, find out what is missing, etc.
thank you for answers. I modified my my project. now I is synthesized and implemented successfully. but there is just 9 warnings about "no input delay" and "no input delay". I don't think that those are important. I still can't read or write into the sdram. I have no idea. I don't know what I should do. its uart port also don't work.
this is my block diagram.
They are important and it depends on the project implementation.
If you can tx/rx data successfully via your ports and Vivado timing analysis gives you a thumbs up, then you may ignore it for now.
