Re: dublex 8951
To increase the number of inputs/outputs just add port expander (for example 82C55), to increase the size of data memory add external RAM and to increase the size of program memory use 8051-derivative with 64kB of program memory (DS89C450, in the 8051-family one of the fastest µC) and so on ..
By connecting several 8051s in one system you will not gain much, as the two possible ways of connecting them are through their serial ports (UART or I2C, for those which have I2C) and serial port can be notoriously slow ..
Why would like to do that ?
If you need more "power" go for more powerful microcontroller, maybe 16-bit or more is what you need ..
Regards,
IanP
