versace427
Newbie level 3
gps to pic
I'm not sure how to do this...and I'm also not sure what PIC to use. I think I want to use PIC 16F690. The output from the PIC will be sent to a Spartan3 board. This is a small part of a project that I am working on with a group of people. I'm responsible for the GPS. We have to build an autonomous robot, similar to the DARPA challenge. I have never worked on anything like this before and would appreciate any insight.
I'm using the Garmin 18LVC. I have already connected it to a DB-9 connector and have been able to read the output sentences. I may also need some example code..if anyone has it. The GPS is a secondary system to deadreckoning. The robot will also have ultrasonic sensors, IR sensors, compass and servo along wiht other mechanisms that will enable to run a course.
I'm also not sure what output sentences I should capture..$GPGGL? Considering that every ASCII is 8 bits will the 16F690 handle the data well?
Thanks
versace427
Thanks
versace427
