How to interface flash and LCD without using level converter
mystery
Full Member level 2
Full Member level 2
Turkey
MSP and 5V
Hi all
I want to interface MSP430F149 with a 5V flash memory (AMD29F010) and a graphic LCD. boths supply is 5V . How can I interface this flash and LCD without using a level converter.
thanks for your future response
MSP430F149 interfcae with 5V
U can connect 5volts device with MSP 430F149 with pullup resistor, I have integrated 5v 20*4 LCD and GPS receiver to MSP430F148
ARE TOU SHURE???
I did A DESIGN not LONG AGO using a MSP430F1101
and ANOTHER with MSP430F413 and yes my LCD was also 5v
I burned both chips when i tried tu pull'em up at 5V..
I couldn't programme them any more ...
once i designed just using 3v no more problems
the data sheet specifies a VOH por the Output ports MAX = VCC
and the VCC MAX = 3.6 .. some place i read that they will withstand 4.1 Volt .. and to get a BETTER contrast in my LCD (5 volt) i had supplied the chip with 3,9 v ..and no damage ... There is an APP NOTE on how to
interface those chips to 5V.. But they don't mention 5v pull ups ..
don't do it
Re: ARE TOU SHURE???
some 24Cxx flash memories accept 2,2v up to 5,5v supply. Try use that
Re: MSP and 5V
I think the use of Dual Supply Translators is the best choice for Your design. Check in:
and see what device is best for Your design requeriments!
Gorkin
MSP and 5V
Level translators are available from various semiconductor manufacturer which will convert 3.3V to 5volt and vice versa.Also u can use any CMOS buffer with supply 5Volt that will solve u r problem.
