how to interface ds1302 with at89s8252?
tapan.entc
Newbie level 6
Newbie level 6
bhubaneswar, India
i have a problem on ram memory used in ds1302. There is no special registers for sec, min ,date as in other RTC.
So how i will write a code in assembly??
Please help me ...........
please give me assembly code for this.
please help me .......
Re: ds1302 with at89s8252
Hi tapan.entc,
I suggest that you can use forum's search facility to find solutions to your problems because this area might be discussed within the forum. Check some topic as below
regards
bassa
thanks bassa.
thanks for replying...
it will be better if you give suggestion on ds1302.
waiting for ur reply
herewith I upload "Interfacing a DS1302 With an 8051-Type Microcontroller" from MAXIM with C source code "DEMO1302.C" and you can modify the code to suit your requirements (**broken link removed**)
as well you check the following topics
and also go through the following links
hope this will help better
regards
bassa
hello bassa
thanks for replay and giving the links..... i will go for that links.
'but before that i have a request that please go through my asm code
and tell me where i am wrong .
i am interfacing ds 1302 with at89s52 and displaying the time in 2*16 lcd
please check the program and give me suggestion that where i am wrong.
the code is as :
;PROGRAM FOR INTERFACING RTC WITH AT89S8252
;author: Tapan Rout
  	CE  EQU  P1.7        ;
        IO  EQU  P3.4
        SCLK EQU  P1.6
	com_adr  equ 0fe00h	;LCD COMMAND REGISTER ADDRESS
	dat_adr  equ 0fe01h	;LCD DATA REGISTER ADDRESS
	ORG 0000H
	AJMP MAIN
;MAIN PROGRAM STARTS HERE
	ORG 030H
MAIN:
	ACALL LCD_INIT		;initializing LCD
        MOV  R1,#8EH          ;  WRITE PROTECT  MODE
        MOV  R0,#0
        LCALL WRITE
	MOV  R1,#90H          ; TRICKLE CHARGER REGISTER AND DIODE SELECT
        MOV  R0,#0ABH		;2 DIODES, 8K
        ACALL WRITE
        MOV  R1,#80H          ; WRITE  SECONDS
        MOV  R0,#0
        ACALL WRITE
        MOV  R1,#82H          ; WRITE MINUTES
        MOV  R0,#05H
        ACALL WRITE
        MOV  R1,#84H           ;WRITE  HOURS
        MOV  R0,#11H
        CALL WRITE
        MOV  R1,#86H          ; WRITE DATE : 27
        MOV  R0,#27H
        ACALL WRITE
        MOV  R1,#88H           ;WRITE  MONTH : 9(SEPTEMBER)
        MOV  R0,#9
        ACALL WRITE
        MOV  R1,#8CH          ; WRITE YEAR : 09 (2009)
        MOV  R0,#09H
        ACALL WRITE
	mov scon,#50h
	mov tmod,#20h
	mov th1,#0fdh
	MOV TL1,0FDH
	mov tcon,#45h
	setb tr1   	;*/
SS:
  	setb TI
 SS1:	MOV  R1,#81H         ; READ SECONDS
        CALL READ
        MOV  20H,R0
        MOV  R1,#83H         ; READ MINUTES
        CALL READ
        MOV  21H,R0
	MOV  R1,#85H         ; READ HOUR
        CALL READ
        MOV  22H,R0
        MOV  R1,#87H         ; READ  DATE
        CALL READ
        MOV  23H,R0
        MOV  R1,#89H         ; READ MONTH
        CALL READ
        MOV  24H,R0
        MOV  R1,#8DH         ; READ YEAR
        CALL READ
        MOV  25H,R0
DIS:
	MOV A,21H		;read minutes and display in lcd
	PUSH ACC
	MOV A,#86H
	ACALL COMNWRT
	ACALL DELAY
	MOV A,#':'
	ACALL DATAWRT
	ACALL DELAY
	POP ACC
	ACALL ASCIICONV
	MOV A,22H		;rad hours and display in lcd
	PUSH ACC
	MOV A,#84H
	ACALL COMNWRT
	ACALL DELAY
	POP ACC
	ACALL ASCIICONV
	MOV A,22H
	JB ACC.5,GO		;check the condition for AM or PM
	MOV A,#8AH
	ACALL COMNWRT
	ACALL DELAY
	MOV A,#'A'
	ACALL DATAWRT
	ACALL DELAY
	MOV A,#'M'
	ACALL DATAWRT
	ACALL DELAY
	SJMP GO1
GO:	MOV A,#8AH
	ACALL COMNWRT
	ACALL DELAY
	MOV A,#'P'
	ACALL DATAWRT
	ACALL DELAY
	MOV A,#'M'
	ACALL DATAWRT
	ACALL DELAY
GO1:
	JNB RI,SS1
	CLR RI
       AJMP  SS
;WRITE  OPERATION
  WRITE:
  	CLR  SCLK		;CLEAR SCLK LINE
        NOP
        NOP
        SETB CE        		; SET CE  HIGH FOR WRITE OPERATION
        NOP
        MOV  A,R1		;LOAD THE ADDRESS
        MOV  R2,#8		;COUNT =8
  WRITE_1: RRC  A          	;
        MOV  IO,C		; SEND LSB FIRST AND THEN CONTINUE
        NOP
        NOP
        SETB SCLK
        NOP
        NOP
        CLR  SCLK
        DJNZ R2,WRITE_1
        NOP
        NOP
        MOV  A,R0		;LOAD THE DATA
        MOV  R2,#8		;SET  COUNT =8
  WRITE_2: RRC  A          ;
        MOV  IO,C
        NOP
        NOP
        SETB SCLK
        NOP
        NOP
        CLR  SCLK
        DJNZ R2,WRITE_2
        NOP
        NOP
        CLR  CE
        NOP
        NOP
        RET
;READ OPERAION
  READ:
  	SETB  CE		;SET CE
        MOV  A,R1		;LOAD ADDRESS FIRST
        MOV  R2,#8
  READ_1: RRC  A
        MOV  IO,C		;MOVE THE ADDRESS THROUGH IO PIN
        NOP
        NOP
        SETB SCLK		;SET SCLK
        NOP
        NOP
        CLR  SCLK		;CLEAR SCLK FOR WRITE OPERATION
        DJNZ R2,READ_1
        NOP
        NOP
        SETB IO
        CLR  A
        CLR  C
        MOV  R2,#8
  READ_2: MOV  C,IO
        RRC  A
        NOP
        NOP
        SETB SCLK
        NOP
        NOP
        CLR SCLK
        NOP
        NOP
        DJNZ R2,READ_2
        MOV  R0,A
;        ANL  A, #7FH
        CLR  CE
        RET
;LCD INITIALIZATION
LCD_INIT:
	MOV A,#38H
	ACALL COMNWRT
	ACALL DELAY
	MOV A,#0CH
	ACALL  COMNWRT
	ACALL DELAY
	MOV A,#01H
	ACALL  COMNWRT
	ACALL DELAY
	MOV A,#06H
	ACALL  COMNWRT
	ACALL DELAY
RET
COMNWRT:
	MOV DPTR,#COM_ADR
	MOVX @DPTR,A
	NOP
	NOP
       RET
DATAWRT:
	MOV DPTR,#DAT_ADR
	MOVX @DPTR,A
	NOP
	NOP
       RET
ASCIICONV:
	PUSH ACC
;	MOV A,R0
	SWAP A
	ANL A,#0FH
	ORL A,#30H
	ACALL DATAWRT
	ACALL DELAY
;	MOV A,R0
	POP ACC
	ANL A,#0FH
	ORL A,#30H
	ACALL DATAWRT
	ACALL DELAY
RET
DELAY:
	MOV R3,#200
BACK:	MOV R4,#255
	DJNZ R4,$
	DJNZ R3,BACK
RET
        END
tapan.entc said:
hiii pranam77,i am not able to attach the file. can u tell me
If you are trying to attach a hex file, or a source code, you cant. You have to ZIP it or compress it in .RAR and then Upload it. Cheers
hello pranam
please see the code and help me ....
i have only one day left for me to complete this code
i hope you will suggest me..
tapan.entc said:
hello pranam. please see the code and help me ....i have only one day left for me to complete this code. i hope you will suggest me..
Frankly speaking, i am not the right person to debug source codes. You may get better replies from fellow memebers. Please be patient....Cheers
