how to interface dc motor+lcd+keypad with 8051?
regin
Junior Member level 1
hi frds,
my aim is to rotate a dc motor connected with 8051 .
by pressing odd numbers in the keypad i want to rotate dc notor in clockwise direction and display in lcd.
if i am pressing even numbers in keypad motor need to rotate in anticlockwise direction and dispaly another string.
please help me ,provideing your ideas in embedded c
For driving motor you can build discrete H-bridge (which is general way to control DC motor rotation direction) or use some integrated bridge like L298, LMD18201 or similar. For buttons see any microcontroller related tutorial, this is the most basic thing ever. As for LCD, if is has HD44780 compatible controller (which i'm almost sure it has) you can find TONS of info and libraries too.
Reactions: regin
    regin
Can anyone give me the idea how can i respond to different keys from keypad interfaced with 8051?
for lcd tutorial
for dc motor tutorial
for keypad interfacing
If i press key on keypad interfaced with 8051 then program jumps to defined label . Mean how can i program 8051 so that it compare the pressed key and if key is nt that i want them program control jumps to defined label.
