How to interface ADC with PIC micro using SPI protocol?
preethi_das
Newbie level 3
Newbie level 3
I want to interface ADC with PIC microcontroller using SPI protocol.and i want to know how SPI works .wat is the protocol ???? i want a detailed explanation about the protocol can any body please help me.
spi detail explanation
In general you have 4 lines when using an SPI device:
/CS -> active low chip select that selects a specific ADC if you have multiple in your system (some ADC will start conversion only if the detect a falling edge of the signal)
SDI -> serial data input from SPI master (the one that generates the CLK signal is the master), usually not available on SPI ADC
SDO -> serial data output: data is bitwise clocked out from your ADC to the SPI master device (MCU)
CLK -> clock generated by the SPI master; SDI and SDO are synchronized to this signal when /CS is L
Concerning the exact timing for your system:
Check your ADC timing requirements in the ADC datasheet! A MCU has usually very flexible interface that can be programmed in different modes.
Anyway, take a look at http://www.ramtron.com/products/appnotes/spibuscomp.pdf which gives you some more information about the different SPI modes, addressing etc.
Hope it helped,
Maddin
motorola spi protocal
You could find some more information at Motorola's site
see for ex. **broken link removed**
Yes, search Motorolas site for info, application notes and examples.
In fact Motorola invented the SPI interface.
