How to interface 8051 hardware with PC using USB
aschahar
Newbie level 1
Newbie level 1
India
how to interface microcontroller with pc
Please help ....
I have a hardware based on 8051. I want to interface with PC using USB not parallel port. Would C be able to give instruction from PC or I have to use some other software for that ???....
Your suggestion would be helpful ....
8051 interfacing to usb
most simple solution is go and buy a good RS232 to USB converter and this will create virtual COM port.Do rest as u want
interfacing 8051 with usb port
Yes, you could certainly create programs in C that will comm with your USB port as PC being host. Your 8051 then is required to comply as USB device, either with an integrated or add on controller.
