How to interface 200mA current output High Pressure sensor to PIC ADC?
unhappy
Member level 3
Member level 3
NOIDA (NCR Delhi region),India
I am in need to use MLH series High pressure sensor of Honeywell make to interface with PIC16F887. Can anyone suggest basic electronics circuit to be used Here.
Note Sensor gives ratio-metric output from 0 to 200mA
Your PIC has an ADC. One option could be an op amp current to voltage converter between the sensor and the ADC.
All depends on voltage and current.
So we know the current..but we don't kniw what the valid input voltage range is.
Let's say it's 0..3V then you just need to select a resistor according Ohm's law to generate 3V @ 200mA
Then you say ratiometric....so the output proportionally depends on the input. We have no information what this "input" is.
Is it voltage or current? What range?
To measure ratiometric values...a good solution is to feed the sensor "input" infirmation to the ADC_Reference.
Low pass filtered, properly decoupled with a capacitor ... with identical time constant as the sensor_output_to_ADC.
As so often: a picture says more than thousand words. What about a (hand drawn) schematic?
Klaus
200mA is an unusually high current, the industry standard is 4mA to 20mA (zero to full scale). Check the value before going further as it would make a huge difference to the interface design.
Brian.
