how to integrated PLIs with ncverilog?
sqyu
I know how to integrate PLIs with C@dence ncelab, ncsim with the
Makefiles or pliwiz. However, I can not find a way to integrate PLIs
with ncverilog. So anyone help me? Thx.
As I know, ncverilog=ncvlog+ncelab+ncsim. If you use static linking, don't worry, ncverilog will work. If you load the pli lib via command line, make sure add +loadpli1 when invoke ncverilog.
you are right. when I build ncelab and ncsim well, ncverilog works.
later I find it is very clear because in Cadence document the ncverilog
has the options to specify which ncelab and which ncsim you want to use.
so no problem now :)
You can use the dynamic linking method.
