How to integrate compiler under CodeWright?
ltg
Member level 4
Member level 4
I want to integrate my Hi-Tech PICC compiler with CodeWright, but I failed how then I following the manual of CodeWright. Do some of you have experince about it how to set up? Would you please share you experince? Thanks in advance!
Best Regards,
ltg
use makefile
you can build a makefile, then set make path in codewright
