How to install SRPM using YUM ?
omara007
Cairo/Egypt
How to install SRPM ?
I searched the internet and they say use YUM .. but I don't know what is YUM or how to use it !
Re: How to install SRPM ?
I assume you are using RedHat or some other distribution which uses RPM.
There are two flavors of RPMs: binary & source code. Source code are designated by ending with -src.rpm rather than just .rpm
Installing source rpms (SRPM):
Unlike ordinary packages, they can't be uninstalled using RPM. SRPM packages are not under the control of the RPM database. All RPM does is copy the files contained in the package to the hard disk. SRPMs are not listed in the RPM database.
A source RPM (SRPM) package typically contains a gzipped tar archive with the source files, and an RPM spec file
Listing the contents of a source rpm:
# rpm -qpl xmms-1.2.10-1.src.rpm
xmms-1.2.10.tar.gz
xmms.spec
Source rpm can be installed just like any other rpm with "-ivvh" flags
# rpm -ivvh xmms-1.2.10-1.src.rpm
For more information look at the following page
https://technopark02.blogspot.com/2004/09/linux-installing-source-rpm-srpm.html
Best regards,
v_c
