How to install SOC22 in SUSE9.0
smilodon
Member level 2
Member level 2
When i Run: ./setup.sh in darddisk or in CDROM, there always exist some mistake in setup process. There are some sentences like this:
Missing file: /mnt/CDROM/SOFTLOAD.TAR\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.0\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.1\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.2\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.3\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.4\c
Missing file: /mnt/CDROM/IMAGES.DIR/FS.5\c
The ./setup.sh is not being run from the CDROM\c
Run ./setup.sh from the mounted CDROM
I dont know what's wrong? Can anyone help me?
Thanks a lot
what happens is that..when u copy the files,they are not being copied properly.just coipy them once again.i did have the problem.this seems to a problem with linux itself,since unlike windows it does not coimplain if a file is not copied properly.
regards
amarnath
regards
amarnath
I knew that the copy process is not proper, but all the files are in harddisk. And other information is just something about copyright,which i saw in setup.sh. I wonder if setup.sh exist some problems? I will burned it a cd with iso format, maybe it must be a iso file in cd? Or i will try install a redhat7.3 and try the install.
Who can help me?
Regards
Zhao
I had the same problem. I think u have unzipped the soc in windows. However, windows changes the filename from capitel to small letter!
SOC22 doesn't sopport SUSE9.0
Yestoday i have installed SOC22 successfully. The problem do come from the unzip in windows. Thanks a lot
Added after 4 minutes:
I installed SOC22 successfully under SUSE9.0, but i can not start it, the information showed the installation is OK and the license is OK, but it told me:the segmentation fault.
Anyone succed in starting SOC22 under SUSE9.0?
Maybe i should install another system Redhat7.3?
Best regards
Installing sucessfully doesn't mean SOC22 supporting SUSE9.0 !
Best regards
Thank you for your reply. I just want to find some solutions in Suse,maybe Redhat7.3 is needed.
Best regards
Hi, I've installed SOC in Suse 9.1. All you need is to add some libs. It works well. As I can remember there was 1 1/2 year ago a discussion about this topic.
Post me if you need specific help! :D
    smilodon
Did you P&R a successful chip ? Just firing up SOC in SUSE9.1 successfull doesn't mean anything
I am so pleased wih you guys, i do learn much knowledge.
But the redhat7.3 is actually poor supporting to hardware,which didnot know my microsoft usb mouse yet. Is there a solution for eda and new hardware?
Thanks to all guys!
Several days before I installed SOC3.2 under Suse9.0 which can start.
I think SOC22 is too old to run under suse9.0.
