How to install Medici in Red-had linux7.3. I have a install file E017_medici_instal.exe, but i don't know how to install and use it.
thanks for any advice.
E017_medici_instal.exe is windows version. You have to get linux version of it which will be in *.tar.gz, *.rpm format.
For installing rpm format ,
# rpm -ivh filename.rpm
The documentation of this installation will be installed in /usr/shar/doc
You can find there the usage instructions.
For instllaling tar.gz format,
#gunzip filename.tar.gz
#tar -xvf filename.tar
The following is common procedure. If you want some specific runtime parameters to be given while installation, it will be there in INSTALL file.
#cd filename
#./configure
#make
#make install
The documentation will be in /doc folder.
The "E017_medici_instal.exe" is work under the Unix platform. Do be fooled about the "exe" extension.
Method
1. upload the file to Unix plateform
2. chmod 755 E017_medici_instal.exe
3. execute it
ps. You can edit it by a binary editor in Windows environment, and you will find it is an shell script
