How to install L-*EDIT 9 ?
se7en
Member level 2
Member level 2
could someone help me about installing L-*EDIT 9?
i install the .tlu file but is doesnt work
am i missing something?
thank you very very much
tanner license
I don't know who wrote this, but it provides valuable infos for me. Hope you so.
"Ledit installation notes:
1) Install products, server(after install, run installer in \lserv710 manually and install it) and license utilities
if u installed everything well, the file leditpro90.tlu.tlu should have a recognized icon (yellow)
2) Double click on the tlu file, this will open the license installer, then press INSTALL
if it won't work, launch C:\Tanner\License\WlmAdmin.exe and with right button click you can add license,
tou your pcserver and its own license file
If u still can't get it to work... then read the file C:\Tanner\License\slm71sys.pdf
3) Now, u have to replace acs.key in C:\Tanner\LEdit84\dxf\lic and C:\Tanner\LEdit84\plot\lib
with the acs.key you purchased
4) OPen lshost file in C:\Tanner\LEdit84\dxf\lic and C:\Tanner\LEdit84\plot\lib and put your hostname inside
End of steps"
BTW, after the above installation, make sure you have the "SentinelLM" also installed correctly. You can check this under the C:/Program Files/Rainbow Technologies/ directory. It should NOT be an empty directory there. Good Luck!
l-edit license file and license server
having trouble with sentinellm. Where do you get it from?
and how to install/configure. rainbow website not clear.
thanks
rn
how to install edit tanner
when connected to LAN.. it works great!
how to install tanner license
Maybe the licnse is in the faulse path.
suggest you install 10.2
tanner l-edit 9.0 license
run installer in \lserv720 manually and install it,then set environment variable TANNERHOST=xxx.xxx.xxx.xxx.It's OK!
Good Luck
install l-edit
What is TANNERHOST=xxx.xxx.xxx.xxx
Should I really put xxx.xxx.xxx.xxx or put the IP address, but what IP address should I put, I tried my ADSL IP, but still fail.
Thanks
tanner license installer
Read carefully file license.wri
Make system variables:
In Win98 put in autoexec.bat strings:
SET LSERVRC=C:\WINDOWS\lservrc
SET TANNERHOST=XXXXXXX
In win2k/XP:
Right-click on the My Computer icon.
Select Properties from the menu.
In the Properties dialog, select the Advanced tab.
Click Environment Variables…
Press Alt+W to open the New System Variable dialog box.
In system varyable TANNERHOST I use my computer name. You can see it in Network Properties. (As I have no network at Home). The Name must be in English. License installer put file lsevrc only in c:\windows folder.
In addition to TCP/IP protocol I add NetBEUI (Network Properties) (In win98)
ledit cannot install
SET TANNERHOST=127.0.0.1
The above setting is suited for any IP, regardless of certain physical IP.
If your system is XP, excute either lserv.720/winnt/lservnt.exe or
lserv.720/win9x/lserv9x.exe. Note that once the lservnt.exe file was
excuted, this license daemon will be automatically started at
every power-up.
tannerhost
If I have no network working, how to setup?
Re: install L-*EDIT 9
look on microsoft site for media sence desiabled.
if u do not have ethernet jack pluged in windows removes the tcp services.
hock
IS THERE ANYBODY HAS BOOK ABOUT LEDIT
