how to install ic5033 update?
qutang
Full Member level 5
Full Member level 5
I have installed ic5.0 on my rh7.3.I want to install the ic5033 update,how to install?
does I need another user or another install_path?
Change your directory as .../Cadence/install/bin.lnx86 and then run softload after that select "update software" selection.
You don't need to install softload again.
Each update package has complete install feature, I mean if you got the update package you can fresh install Cadence. Because if update package don't have all files necessary, it will you request "base version "of IC5.033
If you have base-line IC5033, you can install it directly. not need update from IC50
Hi
It also has update for ISR200410... too.
tnx
hello man could help me, is these any way to download ic 5.033 ?
