how to install cadence ncsim, Synpsys primetime on linux
eda_wiz
Advanced Member level 2
ncsim linux
hi all,
I am newbie with linux. CAn anyone help me install cadence ncsim and primetime in linux. is there any supporting documents...
Also I need help in installing Debussy and verdi in linux.
thanks
what are supporting file for ncsim,cadence
whizkid said:
hi all,
thanks
For Primetime, just run the install.now script and it will guide you through (no need to be root).
As for ncsim, not really sure, but if I remember well, you dont really need to install it, just unpack, set the environment and go....
As for Debussy, just unzip it, set the environment and run.....
Hope it helps..... :wink:
verdi linux install
how to set enviornment for ncsim and debussy
Also can you help with SoC encounter installation
thanks
installing debussy
If you have case sensitive problem on primetime installation, you can delete 2 line list below in install.now:
set toupper = TRUE
set taz = TAZ
how to install ncverilog
When i try to install primetime it asks for location of the synopsys ISO CD .. I give the location of the file ... but the script says its wrong :( help
cadence prime time
what do you get about prim*etim*e ?
iso file or .tar file ?
